Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 02-10-2013, 10:11 AM   #1
Tile grout cleaning and sealing
I am in the process of redoing my bathroom I want to clean the tile grout and seal it. Fortunately, the bathroom is small. The grout is white. I know that there are two kinds of grout and this is the softer kind without sand.
Rats is offline   Reply With Quote
Old 02-10-2013, 03:29 PM   #2
An old Tradesmen
Moved to tiling forum.
Old 02-11-2013, 12:30 AM   #3
congratulations on your life thus far.
cleveman is offline   Reply With Quote
Old 02-19-2013, 05:45 PM   #4
Clean the tile as best you can with vinegar or some other grout cleaner. Make sure any residue is washed off. Seal floor when it's dry. If you can't get the grout completely clean, consider scraping out the existing grout and re-grouting. I've had good luck cleaning with Mighty Indigo.
Frattman is offline   Reply With Quote
Old 02-19-2013, 07:15 PM   #5
Thanks for the tips. I will try this on the weekend.
Old 02-24-2013, 02:48 PM   #6
How do I remove grount that is chipping? I then replace and seal? Correct?
dkkemp is offline   Reply With Quote
Old 02-24-2013, 07:25 PM   #7
Tileguy
JazMan's Avatar
Why is it chipping? Grout does not just chip, the substrate must be moving.
Use a tool like this with the grout blade (not shown) if the joint is at least 1/8";
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Cleaning grout lines/shower tile question Pawl Flooring 0 02-17-2012 04:03 AM
Tile grout color situation jay1028 General Discussion 1 06-26-2010 06:57 AM
