-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Tile grout cleaning and sealing (http://www.diychatroom.com/f84/tile-grout-cleaning-sealing-171589/)
Rats 02-10-2013 09:11 AM
I am in the process of redoing my bathroom I want to clean the tile grout and seal it. Fortunately, the bathroom is small. The grout is white. I know that there are two kinds of grout and this is the softer kind without sand.
beenthere 02-10-2013 02:29 PM
Moved to tiling forum.
cleveman 02-10-2013 11:30 PM
congratulations on your life thus far.
Frattman 02-19-2013 04:45 PM
Clean the tile as best you can with vinegar or some other grout cleaner. Make sure any residue is washed off. Seal floor when it's dry. If you can't get the grout completely clean, consider scraping out the existing grout and re-grouting. I've had good luck cleaning with Mighty Indigo.
Rats 02-19-2013 06:15 PM
grout cleaning
Thanks for the tips. I will try this on the weekend.
dkkemp 02-24-2013 01:48 PM
removing chipping grout
How do I remove grount that is chipping? I then replace and seal? Correct?
JazMan 02-24-2013 06:25 PM
1 Attachment(s)
Why is it chipping? Grout does not just chip, the substrate must be moving.
Use a tool like this with the grout blade (not shown) if the joint is at least 1/8";
Jaz
ervincook107 06-23-2013 05:27 PM
Jaz
It works great?
_________________________
tile grout cleaning tools
JazMan 06-23-2013 09:46 PM
Originally Posted by ervincook107
It works great?
Yes it does, but why is that a question?
Jaz
tilecleaningdud 11-26-2014 05:26 PM
I don't understand the question. Are you looking for a grout cleaner that will work for all kinds of grout? I use Hoover Grout Plus and it has always worked for me on all types of grout. If you don't believe me read some reviews here: grout cleaner reviews
ChiTownPro 11-29-2014 01:34 AM
Seeing this is from the beginning of 2013, l don't think they will be around to answer.
