Tile Grout - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 09:52 PM   #1
Tile Grout
Recently had two rooms done and seems like the grout isn't high enough.
Wondering how thick grout should be in between tile when job is done. Should it be even with the tile top so as to get a smooth effect or is there no standard for this?
Thanks!
CheriAlli is offline   Reply With Quote
Old 05-16-2012, 11:11 PM   #2
www.No-Curb.com
JohnFRWhipple's Avatar
Thanks!
Can you upload a pictures so we can see? Keeping the grout level with the tile is hard to do with larger grout joints and easier with tight ones.
Often when tile setters finish grouting they over wash it and rake away the grout between the tiles. It is best to follow the grout's instructions and allow the grout to set up enough before final cleaning and tooling.
Sorry to hear about your problem.
JW
JohnFRWhipple is offline   Reply With Quote
The Following User Says Thank You to JohnFRWhipple For This Useful Post:
CheriAlli (05-17-2012)
Old 05-16-2012, 11:16 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
No, the grout should not and will not be even with the top of the tiles. Ya have to wipe it off the tiles, and in doing so the sponge will remove grout in the joint. Some tiles and some conditions make grouting a challenge. You got pics? A more thorough explanation.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Tile Grout Touchup kennykenny Tiling, ceramics, marble 1 04-15-2012 06:58 AM
Sealing grout on a glass tile mosaic backsplash? smithers76 Tiling, ceramics, marble 1 05-08-2011 07:44 AM
Installing floor tile but don't want grout gap to turn black overtime gatorade Flooring 4 02-07-2011 12:13 AM
Marble tile - would rather not use grout epeterson777 Tiling, ceramics, marble 3 05-27-2009 03:47 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
