Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-09-2009, 06:34 PM   #1
Default Tile a garage floor... Or why not.
I have been wanting to finish the floor in my garage for 2 years now. I just can't decide what to use. The epoxy finishes seem to last a few years at best. The PVC garage tiles worry me because water will get under them and not dry out and they are hard to keep clean. PVC would be about $2.50 a square foot and the epoxy slightly less. I would like to keep the cost in the $3 - $4 range
What about tile? I live in PA near Pittsburgh and once or twice a year it may get to the freezing point inside near the OH doors. This garage houses the car and truck we use the most so snow and salt melting off will be a factor a couple month each year. So... is it possible to tile this? Would it be too slippery? What tile would I use? Would there be anything out of the ordinary about laying tile in this situation I need to know? I assume using a floor jack would be out of the question but what about using a bottle jack on this floor?
I am no stranger to building, remodeling and repairing almost anything residential but I can not seem to find anyone with first hand experience on this subject.
Thanks in advance for you help and ideas...
Rege
RegeSullivan is offline   Reply With Quote
Old 10-11-2009, 09:57 AM   #2
epoxies last us 10yrs when they're applied properly INCLUDING prep,,, then again, we don't use apron store/sher-wms stuff,,, weight's more destructive when its static than dynamic ( rolling ),,, that's why airplane parking aprons're thicker'n runways/taxiways,,, why not acid stain the floor, apply an aliphatic urethane sealer, & saw grout lines in it ? ? ?
these ' tiles ' are 2'6x2'6 - 2yrs & still look the same,,, we also use the urethane as a topcoat on epoxies to protect them.
$3 - $4 is about 60% of buying the whole job so, w/diy labor, you'll be fine
ps - the house numbers're reflective at nite & 14" tall so poor vision's no excuse for missing the home.
itsreallyconc is offline   Reply With Quote
Old 10-11-2009, 10:11 AM   #3
General Contractor
joasis's Avatar
I have seen a garage floor sprayed with a poly-urea with a light aggregate, and it was pretty neat. Think of a bedliner on a truck, and how it would look on your floor. All you need to do is find aspray insulator that is willing, and grind the floor for a prep.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulation Services
Oklahoma
405 314 5802
joasis is offline   Reply With Quote
Old 10-11-2009, 11:01 AM   #4
usually, polyaspartics/polyureas're spread w/squeegee then backfoll'd w/spik'd roller,,, base coat, aggregate/vinyl chip/top coat order,,, slightly different mtl than bedliner that's mix'd at the head then spray'd,,, then again, they're MUCH tougher than bedliner, too
Old 10-12-2009, 11:12 AM   #5
Thanks! this give me a couple of more options to consider. I really like the idea of acid staining and the aliphatic urethane sealer. Where can I purchase the material and read about the proper application?
Rege
Old 10-13-2009, 08:46 AM   #6
we buy dec conc mtls from elitecrete but they only sell thru authorized distributors to trained installers,,, there are mtl suppliers to be found by googling ' decorative concrete forum '
More On This Topic
Where To Play Jacks
Where To Play Jacks by Expert Village
Hi, I'm Jamie Peterson. I'm here on behalf of Expert Village and I'm here to teach you how to play jacks. Jacks is a really fun game and it can be kind of tricky. But once you get the hang of it it's pretty easy. The first thing you need to do is play... Read More »
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
In this segment I'm going to talk to talk to you about how to bounce a ball. As you can see I'm on tile today and it's a little tricky cause it has cracks in it. So I really want to practice right in the middle but if you're on hardwood floor or linoleum... Read More »
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
[IMG] code is Off
Raising up my garage jimmyfloyd Building & Construction 5 09-18-2009 12:39 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 04:57 PM
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 09:05 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 06:57 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 04:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
