Tile Fracturing Near The End Of Cut W/ Saw - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 02:23 PM   #1
jep
Rewards Points: 33
tile fracturing near the end of cut w/ saw
Hi. Whenever I cut tile the tile with a saw, the tile tends to fracture near the end of the cut when there is about 1" left. Then instead of a perfect straight line there is a little divot at the end. This happens both with my $100 home depot saw but it also happens with the fancy rented saw I'm using right now. This is for our kitchen so I want it to be perfect. I have a fair bit of old tile from previous jobs to practice on before I start on the real thing, but I do want to finish the job today. Any tips? Am I pushing too fast?
My tile are nominally 12" x 24". I have to cut a few of them in half and I'll have to make some angle cuts once I get warmed up.
jep is offline   Reply With Quote
Old 10-08-2012, 03:46 PM   #2
Rewards Points: 12,858
I guess it's easy enough to find out if your cutting to fast at the end of the cut, slow down.
Old 10-08-2012, 06:35 PM   #3
jep
Rewards Points: 33
Thanks!!
Old 10-08-2012, 09:16 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 232
Aside from going slow especially the last few inches, try pushing down on the tiles so it's firmly on the table and well supported. Large tiles can be a pain both in setting and cutting.
Jaz
JazMan is online now   Reply With Quote
The Following User Says Thank You to JazMan For This Useful Post:
jep (10-09-2012)
Old 10-10-2012, 06:58 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I hope your using wet saw and not a saw.
Score your cut 1st! With tile cutter, glass cutter or raiser knife you will be amazed on the out come of less chips if any.
JetSwet is offline   Reply With Quote
Old 10-10-2012, 07:20 PM   #6
jep
Rewards Points: 33
THanks! I didn't think of scoring it but I did start taking a shallow pass with the saw and then a deep pass. That pretty much worked. And yes the fancy rented tile saw was a wet saw (as was the $100 home depot saw). It was too small for my tile though. If I ever do this again I won't rent a saw that requires such gyrations. Funny thing was that the $100 home depot tile saw worked better on the precision cuts. It has what I assume is a really cheap skinny blade but I feel like I have better control with it than with the rental saw which was a heavy duty piece of equipment.
Old 10-12-2012, 06:47 PM   #7
Your blade is pulling to one side.
Judging by the size of the tile it is porcelain. Porcelain is very hard.
Draw a square straight line on the tile with a sharpie or something that won't wash off. As you cut the tile does it stay on the line? Not just close. On the line. If not place a finger on the side of the blade and push on it to keep it on the line. MAKE SURE THE BLADE HAS PLENTY OF WATER ON IT. A diamond blade with water on it will not cut skin. Without water will burn through skin. Does not smell good, trust me.
Rex
atvrex is offline   Reply With Quote
Old 10-12-2012, 09:46 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 232
Things I will not waste my time trying;
not even a razor knife.
If the blade-to-tray alignment of off, I would make the adjustment, very simple on most saws. Use a square to check alignment first.
Jaz
Old 10-12-2012, 10:48 PM   #9
Pro
JetSwet's Avatar
Rewards Points: 502
Per-scoring cuts help out a lot with a lot of things, tile, counter tops, laminate, peal and stick. Don't knock it if you have not tried it.
Old 10-12-2012, 11:27 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 232
I thought the subject was cutting ceramic tiles on a wet-saw. And you're right, I know better than to try scoring with a utility knife.
Jaz
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
