-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Tile Floor Slippery (http://www.diychatroom.com/f84/tile-floor-slippery-39540/)
jamiedolan 03-03-2009 12:02 AM
Tile Floor Slippery
HI
After 2 months with our tile floor installed in our porch, it still looks great.
However, it is a death trap when wet, slippery as ice.
Can I put anything on it, like a polish or finish of some kind to make it a bit safer? They are the standard factory glazed ceramic tiles.
Jamie
Raul Garcia 03-03-2009 01:32 AM
re: slippery floor
Jamie,
You might want to look into a applying a sealer with traction control. There is a product called skid safe, and we also use an additive to sealers that looks like a white powder. I think its called sure step. You can mix it into the sealer then apply it with a heavy duty pump sprayer. Tape off all surrounding areas. Ask your local concrete/ masonry supply store and they should have some good advice too. Hope this helps.
jamiedolan 03-03-2009 03:52 AM
Originally Posted by Raul Garcia (Post 239547)
Jamie,
Thanks. I'm glad to know there are products that will work. I'll have to check around for them. Thanks
Jamie
ccarlisle 03-03-2009 06:51 AM
Sure, there are products that will reduce the coefficient of friction...some actually etch the surface and some are just topical. But that aftermarket industry is rife with liability issues and getting someone to put down a product, or just buying a product, might be harder than you think.
But, that aside, I am wondering who specified a ceramic tile in an outdoor environment, even though it is in a porch...? I imagine Wisconsin winters to be somewhat wet and cold and no matter what the covering of the porch - nor what's underneath it - there would be issues there. I mean even in Florida there are humidity issues...so I think 'ceramic' was not the best choice initially. Porcelain would have been better, and the small price difference would surely have not been a factor not to consider it.
:eek:
Bob Mariani 03-03-2009 06:55 AM
Ceramic is still around due to the rise of box stores. Otherwise you would not even see this stuff. Best to plan on using a correct flooring, as posted after market applications that work are not DIY projects.
JazMan 03-03-2009 10:11 AM
Bob,
Can you explain what you meant to say, I don't understand a word of it.
Jaz
Bob Mariani 03-03-2009 10:47 AM
it means ceramic tile is quickly being surpassed by the more superior product -> porcelain.
R&D Tile 03-03-2009 10:58 AM
Porcelain IS ceramic tile.:yes::whistling2:
Bob Mariani 03-03-2009 11:11 AM
Yes, but there is too different classifications. Porcelain, albeit a ceramic tile is made with more refined materials. Porcelain tiles are frequently found in floor applications, outdoor areas, and in cold weather climates where freezing can occur. With their low absorption capability they are less likely to crack in cold weather climates. such as what this poster should have used. The cheaper ceramic class of tile has not real use except for cheap applications, which is what I was talking about. In the past Porcelain (class) was too expensive, but costs are quickly leveling out.
clarie44 03-03-2009 02:42 PM
re: Slippery Tile Floor
To Jamie, I just wanted to let you know that I am pretty sure this is the solution to your slippery tile problem.:wink:
My friend Jenny had the same problem but it was around her pool deck. She used a product called Johnny Grip, she told me that all you do is mop it on and it stops the tile from being slippery. Jenny said it worked really well. I think there site is www.slipperytile.com You can give it a try. She was happy with it.
jamiedolan 03-03-2009 07:35 PM
:eek:
I thought tiles seemed like a nice idea. It is a room attached to the house, fully enclosed, with a full foundation, but no basement under it. It is insulated with new windows and doors.
I've been to a number of flooring stores and talked to them about several of my flooring projects, including this one. They all seem to be interested in selling laminate flooring, which I am not interested in. There are of course floor stores that deal with tiles, but have found none that were very knowledgeable.
Porcelain / Ceramic? I'm confused. I bought these tiles at home depot, there was a grading system for hardness, and these are rated as the best. For whatever that's worth.
Jamie
ccarlisle 03-04-2009 06:31 AM
Well, you're right - tiles are a nice idea, it's just that not-any-ol'-tile-will-do...because it is glazed, the top surface of a ceramic tile is, well like...uh glass. That was intended. However, porcelain tiles are made slightly differently and are not glazed the same. They are almost solid clay and therefore have a rougher top surface besides being denser so they don't absorb moisture the same. That makes porcelain ideal for outdoor applications - they don't absorb mosisture and they don't have a slippery surface.
Even indoors where there are changes in temperature and humidity, ceramics would be slippery, thanks to condensation. A bit like what we have up here: 'black ice'...If underneath the room you have a cooler temperature than the 'living' part of the porch, you will also have condensation issues.
'Hardness' of the tile - or its colour - are not major characterisitics you're looking for in this application. :no:
I would look into putting down area rugs or runners in the main walking area, something moisture-resistant i.e. that won't degrade with moisture. Cotton and wool are out, therefore so are oriental rugs. Nylon is OK, polypropylene or polyester better. Depending on your size of area, $200 can get you an area rug that you could interchange with another one every 6 months or so. Held down with rubber underpadding...
yesitsconcrete 03-05-2009 05:54 AM
i wouldn't worry too much as this porch's in wisconsin,,, pretty sure after a couple yr's worth of freeze/that cycles, we'll see this poster again :yes:
rusty baker 08-22-2009 11:11 PM
Not sure I would waste the money on a rug. After a couple of years the tiles will be cracked anyway. The person who sold you the tiles in a Big Box was probably selling lumber the week before.
jamiedolan 08-23-2009 11:10 AM
Porch was the wrong word :
"It is a room attached to the house, fully enclosed, with a full foundation, but no basement under it. It is insulated with new windows and doors. "
Only difference from the rest of the house is that I may not keep it up at full temp all the time.
I now realize most people here are thinking of a porch as something outside.
Jamie
