Tile Floor Removal - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-12-2014, 11:20 AM   #1
Tile floor removal
I have about 500 sq ft of travertine floor to remove. It's on 1/4 in hardy backer and that's on 3/8 particle board that's over the sub floor. I need to remove this down to the sub floor to complete my nearly whole house tile job. What is the best method to remove this?
patrickb is offline   Reply With Quote
Old 01-12-2014, 11:27 AM   #2
Rewards Points: 12,854
This what I use with a tile blade. It's a wide flat bit with a raised area in the middle that lefts and splits the tile.
Home Depot rents them.
http://www.coastaltool.com/bosch/112...10700000000159
Old 01-12-2014, 12:58 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
Patrick,
If the method I posted at the other site doesn't work well for you, using the demo hammer is a good step cuz you're removing the tiles and then the other layers. This way will take longer, but will require less force.
From other thread:
There's no easy way, but I would start at a doorway and try to get under the particle board with demo bars (crow bars), one in each hand. You'll improvise as you go and figure it out. There's no one way.
Have help and wear the proper clothing and eye protection of course.
Got plans for the new floor yet? Hopefully a better plan than the way that floor was done.
Jaz
Jaz
Old 01-12-2014, 01:36 PM   #4
Cutting that subflooring between the joist and cut along the two outside walls so your working in sections will help make it go faster.
Old tool I found that a big help doing demo work is this.
http://www.thegutster.com/index_2.htm
I got mine at Northern Tool.
tile shower replacement with new tile Axhammer Remodeling 86 08-19-2013 08:22 AM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
