Tile Floor Before Or After Door? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-15-2013, 11:27 AM   #1
Trucon01's Avatar
Rewards Points: 510
Tile floor before or after door?
Hi All,
I'm gutting a bathroom and completely removed the door and jamb. Should I put in a new door and jamb before I tile or after? Does this even matter?
I also will need a carpet to tile transition. Before or after the door?
Thanks,
Jeff
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 04-15-2013, 11:45 AM   #2
Rewards Points: 34
Put the door back in first. Then do the transition.
Dan
djlandkpl is offline   Reply With Quote
Old 04-15-2013, 11:54 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
Typically your threshold will be centered on the door slab so when the door is closed you can see only tile from the inside of the bathroom and only carpet from outside of the bathroom.
+1 for putting in the door before tiling. I think you'd have to cut down your frame and jambs if you tiled first.
brockmiera is offline   Reply With Quote
Old 04-15-2013, 12:02 PM   #4
Rewards Points: 528
it is easier to put the tile down first. Theo0nl problem with that is where do you stop the tile.
either way the door frame will most likely have to be cut down.
framer52 is offline   Reply With Quote
Old 04-16-2013, 10:13 AM   #5
firehawkmph's Avatar
Rewards Points: 1,884
Put the door in first if you're worried about having the tile stop under the door. You can probably sit your door on top of the underlayment and have the carpet and pad cover the half of the jamb where the carpet is going to go. You could always notch your jamb to slip the tile under it with a vibrating multi tool. I normally use a 4" wide marble threshold at the doorways. Personal preference.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-16-2013, 07:23 PM   #6
Rewards Points: 4,796
Personal preference always wins. Have to say though - that's gigantic and a bit odd :-)
jeffnc is offline   Reply With Quote
Old 04-16-2013, 07:35 PM   #7
Around here in Ohio its done all the time. Probably more so than the narrow thresholds. The wider ones fit very nicely into the width of the jamb. They have a nice bevel on each side to transition into the tile. Eh, different strokes...
Mike Hawkins
Old 04-17-2013, 03:47 AM   #8
It does fit the jamb very nicely. I think that actually looks good with the door open.
It just seems odd with the door closed - you see a big chunk of transition on both sides of the door. But I think that could grow on me....
Question about pre hung exterior door and tile gta Flooring 8 08-16-2012 04:49 AM
Question about pre hung exterior door and tile gta Flooring 0 08-06-2012 04:04 AM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
