Tile Edging Over 1/4" Cement Board - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 10:24 PM   #1
Rewards Points: 18
Tile edging over 1/4" cement board
So I have 1/4" cementboard in place surrounding my fireplace in preparation of putting sheets of glass tile on. The cementboard is on top of wood paneling. Question is, what are ideas for an edge on the vertical corners? I need to be able to hide the edges of both the cementboard and tile.
Gburg109 is offline   Reply With Quote
Old 01-22-2014, 12:42 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 310
How about a picture to better see what you're doing?
There are no trim pieces for glass tiles and usually none needed. Are those vertical corners outside corners? They make metal and plastic trims that might work. Post a few pics,
Jaz
Old 01-22-2014, 06:24 AM   #3
Rewards Points: 13,300
http://www.schluter.com/139.aspx
Old 01-22-2014, 08:08 AM   #4
Rewards Points: 18
The cement board was used to cover the cut out for the fireplace unit. Please excuse the newspaper, I am painting the metal trim around the fireplace.
Tile edging over 1/4" cement board-image.jpg
Old 01-22-2014, 08:08 AM   #5
Rewards Points: 18
Another pic
Old 01-22-2014, 08:29 AM   #6
Is this a gas or wood burning fireplace?
You are planning on installing the tile under that metal trim, right?
Old 01-22-2014, 08:42 AM   #7
Rewards Points: 18
It is a gas burning unit. The metal trim will stay and was planning on tiling the entire surround where the backer board is. The tile would butt up to the existing metal trim and run to the edge of the backer.
Old 01-22-2014, 11:42 AM   #8
K&B Designer
Live_Oak's Avatar
Can you post a link to the module that you are using? What you are proposing won't work with most gas fireplaces as it would violate fire safety codes.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 01-22-2014, 11:58 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Too late now. This question should have been asked BEFORE you installed the wallboard and tile. Now all you can do is install a wood quarter-round or shoe-mold after cleaning up those ruff edges.
Which is ideal for cement board and ceramic tile installation Shawn49424 Flooring 14 01-23-2013 05:01 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
cement board flex (a bit) rtoni Building & Construction 2 12-16-2010 03:01 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
