Tile Cutting - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-08-2013, 12:59 AM   #1
tile cutting
So I have recently bought mosaic sheet tile before thinking. I have bought these sheet that include glass tile stone tile and also stainless steel tile. Now this tiles are very small and I was wondering in anyone knew of a tool I could use to cut all three of these tiles?
lanny is offline   Reply With Quote
Old 10-08-2013, 05:48 AM   #2
Rewards Points: 14,306
Diamond blade on any style tile saw will cut them, but the easiest one to use would be a "bridge" style tile saw.
Home Depot may rent them.
Old 10-08-2013, 06:16 AM   #3
DIY staff
Rewards Points: 7,174
A hand held 4 !/2" angle grinder with a diamond blade could also be used---not as neat as a proper tile saw,but really inexpensive---and a handy tool to have around the house---Mike---
P.S.--I moved this to the 'tile' section---M---
Old 10-08-2013, 07:41 AM   #4
Bill Kearney
Rewards Points: 1,174
Harbor Fright sells a small wet tile saw for pretty cheap. I did a whole bath with it, including cutting a fair bit of marble listello and glass pencils. Just buy a better quality diamond blade than the one that comes with it.
It also helps to lay some tape across the front to help keep the tiles in place, even if they've got a mesh backing (as some tend to slough off when wet).
wkearney99 is offline   Reply With Quote
Old 10-08-2013, 08:22 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
I don't know how you'd hold small mosaics while using a side grinder. I'd be willing to try if someone will volunteer to be the holder.
I think a wet saw with a regular rolling cutting tray works best. I have often used small pieces of wood to hold the tiles in place while pushing the tray.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (10-09-2013)
Old 10-09-2013, 03:23 AM   #6
DIY staff
Thanks for the slap,Jaz---I needed that---think first, then type---
Old 10-09-2013, 09:19 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Mike,
I know you've never tried it cuz since you type so well I'm sure you still have all your digits.
Jaz
Old 10-09-2013, 09:25 AM   #8
Rewards Points: 4,796
I've cut the mosaics (including some glass) with the hand grinder. It's not fun - it's tedious and slow and can cause chipping - but it can be done with patience.
All diamond wheels will cut glass, but only a special glass blade with be optimal - avoid chipping and give the smoothest cut. Whether you want to switch to this blade for just a few glass pieces in your mosaic is up to you.
jeffnc is offline   Reply With Quote
Old 10-09-2013, 03:12 PM   #9
Thanks everyone
The Following User Says Thank You to lanny For This Useful Post:
cutting holes in tile analogmusicman Flooring 2 03-26-2013 05:08 AM
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
Cutting tile bwavem Flooring 5 01-16-2013 09:14 AM
Tile Cutting chade64 Flooring 4 01-16-2012 09:00 AM
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-23-2011 11:04 PM
