Tile Butting To Threshold - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 10:27 AM   #1
tile butting to threshold
putting tile floor in entryway, the tile will butt right up to threshold with no problems. question is do i leave a small gap between threshold and tile then caulk it or fill with grout. my worries are the use of the door in the future and the impact of opening and clsing it. have kids that slam door occasionally. will this cause tiles to loosen or pop.
autumn2011 is offline   Reply With Quote
Old 01-28-2013, 10:36 AM   #2
Rewards Points: 13,270
Use caulking not grout.
You should be able to get caulk that matches the grout.
Depending on the spacing if it's wide you can even get sanded caulk.
Old 01-28-2013, 10:41 AM   #3
funfool's Avatar
Rewards Points: 534
Leave a small line and use tile caulk.
I have seen others and am guilty myself of grouting that joint. After a few years grout line will crack from movement in the threshold. While the caulk will not.
You want at least a 1/8" joint to caulk, ideal you want to match the spacing of the rest of the tile, but a 1/4" caulk joint would not look that good. Use your own judgment here.
funfool is offline   Reply With Quote
"Temporary" tile job? M3 Pete Tiling, ceramics, marble 5 02-27-2012 04:01 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Threshold between carpet and new bathroom tile. Baldy246 Tiling, ceramics, marble 1 03-28-2011 07:31 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
