Tile Baseboard Expansion Gap Is Exposed - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 03:18 AM   #1
Rewards Points: 209
Tile Baseboard Expansion gap is exposed
My cuts are all over the place. I left a perimeter expansion gap around the floor that I layed. They average about a 1/4 inch gap between the cut tile and the wall. But a few of the cuts were bigger almost "1/2 inch gap" or smaller "a little under 1/4 inch".
I thought my Tile molding would cover the expansion gap, but I think the tile is only about a 1/4 inch thick so it will end up showing the gap on some of the 1/2 inch expansion gaps...
Anyone have suggestions to cover these gaps or how to deal with this?
And for the adhering the Tile Molding to the wall should I use Mortar or could I just go with a strong adhesive like PL? Thanks!
crayola110 is offline   Reply With Quote
Old 10-15-2012, 05:40 AM   #2
DIY staff
Rewards Points: 7,174
Grout the gaps that will show--then add the tile---PL premium or similar will work of you don't want to mix up thinset.
Old 10-15-2012, 03:15 PM   #3
Rewards Points: 209
Thanks, I was just wondering if that will fill the expansion gaps or should i just put the tile baseboard first then shove the grout under the gap?
I was actually thinking i might do thinset to make the tile baseboard "stick out more". That way it will cover that expansion gap more I guess I just don't know what I'm doing, on thiing after another keeps coming up with this tile job...
Old 10-15-2012, 09:22 PM   #4
DIY staff
Just grout the wide spots---of you are concerned about expansion---tuck a strip of cardboard against the wall before you grout---
Old 10-19-2012, 09:05 PM   #5
Rewards Points: 209
Thanks, one more question about the border trim/tile skirt, since there is a small crack do you caulk around that? Isn't caulk hard to clean?
Old 10-19-2012, 09:22 PM   #6
DIY staff
You will want to caulk all ' change of planes'----so yes---caulk the wall/floor seam---
Grout cracks--caulk stretches--walls move---
Old 10-19-2012, 11:06 PM   #7
Rewards Points: 209
good to know thanks
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Tile Wall to Tile Floor plus Wood Baseboard hollywood33 Flooring 1 08-21-2012 01:31 PM
Matching baseboard to tile janralix Carpentry 2 12-10-2011 09:33 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
