These are pictures of how it is now prior to tiling.
I'm tiling my concrete floor of my bathroom. Prior to this there was laminate on the floor. I removed laminate and toilet. Toilet flange was over the laminate.
I noticed that there is a good amount of rust and some corrosion on the toilet anchor flange. There was some moisture under the toilet and around the flange. Could I replace this flange easily? Or should I hire a plumber to do it and how much would he cost?
OR
Should I get a couple toilet flange extensions? to make my life easier? (but I'm not sure if this would be the correct way.)
http://www.homedepot.com/h_d1/N-5yc1...1#.UFpBm41lTDE
THANK YOU
