Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 04-29-2010, 12:58 PM   #1
123
Is thinset always necessary?
I am getting my bathroom floors tiled (used to have linoleum). My contractor used nails and screwtight screws to set the hardiback board to the subfloor, without using any thinset. He told me that in new construction/newer subfloors, he would apply thinset, but that my subfloor would not absorb thinset (my house is 22 years old). If he applied thinset, it would eventually dry and crack as we walked on our floors. Is this correct or am I being told a load of garbage?
123 is offline   Reply With Quote
Old 04-29-2010, 05:28 PM   #2
imo it's a load. the reason you put thinset under hardi isn't for stickum it's to prevent poping/flex you can get without it. floors are often uneven and on top of that when you screw down hardi some pokes through the back giving you slight lifted up effect. the thinset gives the hardi a solid uniform surface to sit on that's free of air pockets and high/lows.
racebum is offline   Reply With Quote
Old 04-29-2010, 08:01 PM   #3
Super Moderator
Load of crap---Like racebum said the purpose of the thinset is to fill void and prevent hollow spots.
Durrock is very forgiving ---it is soft enough that it will conform to the contours of a sub floor.
Hardi on the other hand is stiff and springy----it really needs to have a void filler under it.
Sorry-----Mike--
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Thinset removal between inserts(Thinset = TOUGHSTUFF) nylajo Flooring 2 02-15-2010 08:47 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
Thinset application question poolecw Flooring 2 10-15-2008 04:51 PM
