Thin-sets - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 08:02 AM   #1
thin-sets
any one know, can you mix modified with un-modified thinset. I have a 50lb. bag of un-modified that i,m using to apply Kerdi with in my new corner shower before i tile it and was planning on using it on the floor for the tile there, but I;m guessing i wont have quite enough to do the whole bathroom floor. i have partly used bag of modified thin-set as well (about 20lb,s) and i thought i might just mix a bit in with every batch of un-modified i mix when i get to the floor. And I;m tiling on a bed of self leveling concrete I poured to flatten things out. also planning on applying a bonding agent to it before i lay down the thin-set. Any advice?
prehberg is offline   Reply With Quote
Old 02-21-2010, 09:26 AM   #2
I wouldn't, thinset is cheap, go pick up a fresh bag of what you need.
R&D Tile is offline   Reply With Quote
Old 02-21-2010, 02:52 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 240
I think it would be OK to blend the two thin sets. But once open, thin set has a short life span, so unless it's new don't use it.
Jaz
Old 02-21-2010, 06:14 PM   #4
thanks
Jaz
both bags are new, a few days open. using them this week. used a bit of mixed to fill a little gap in the back corner of my corner shower where my cut of the durock went a bit askew (oops!!) to make smooth corner for the kerdi band.seems to be okay. i am using the non-modified thinset for applying the kerdi over the durock and to adhere the tile to the kerdi. just thought if i was a little short when i got to the tiling of the floor i could mix in a bit of the modified to make up the shortage. i know they have slightly different curing times but wouldnt be going near the floor once tiled for a good 24hrs to make sure everything was hard. another thought. as a opposed to mixing, what about using both on the same surface, if i was to run out of one could I switch to the other on the same floor? what would the difference be once i've grouted, once set up there both basically the same thing, hardened thinset.
Old 02-21-2010, 07:58 PM   #5
Military Mom of 4
Snav's Avatar
Jaz
Wow - glad I read this!
I was planning on using up thinset that I opened 3 years ago.
OP - yes, it's pretty cheap - I wouldn't try to mix them together and bet time and tiles on it . . . just buy a new bag.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
Thin set vs mastic/glue for ceramic tile ph3iron Flooring 6 02-17-2009 08:56 AM
How do I wire two separate SETS of 3-way switches together? mflagler Electrical 11 08-30-2008 09:47 PM
