Thin Set Vs Mesh Porcelain Floor Tile Over Plywood Subfloor And Vinyl Flooring - Tiling, ceramics, marble - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 09:06 PM   #46
Rewards Points: 145
Ok so I'll use 1/4 cement board?
wantboost is offline   Reply With Quote
Old 05-14-2013, 09:18 PM   #47
Pro
JetSwet's Avatar
Rewards Points: 502
Yes but remove the 1/4" plywood if that's already on the floor.
Make sure you bed cement board In the thinset and use galvinized screws or nails.
JetSwet is offline   Reply With Quote
Old 05-14-2013, 09:26 PM   #48
Rewards Points: 145
I'm not sure on the term but my subfloor is planked. Its older house ...
Old 05-14-2013, 09:43 PM   #49
Pro
JetSwet's Avatar
Rewards Points: 502
Then you need to give us what size planks. Are they tounge and groove? What size joists. What the span and spacing. Then we can determine if you should keep or pull them up.
If its old house I'd get rid of them.
Old 05-23-2013, 01:04 PM   #50
Rewards Points: 744
Originally Posted by JetSwet View Post
Start a new thread this one is "years" old.
And do this.
Seattle2k is offline   Reply With Quote
