Thin Set Right On The Painted Wall? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 09:40 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Thin set right on the painted wall?
I have never tiled a wall before, and was wondering if I would just put the thinset right on the painted wall or do I need to prep the wall in any way?
I am laying glass tiles behind the pedestal sink in the bathroom. I am covering an area of 2 feet by 8 feet.
Thanks very much.
yummy mummy is offline   Reply With Quote
Old 11-19-2010, 07:19 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
Hi Mummy,
Nice to see you again. Thin set will bond fine to painted walls. Just do the normal prep and add sanding the wall to give the thin set a little more bite.
Be sure to use the proper thin set for those glass tiles. What do you have?
Jaz
Old 11-19-2010, 09:02 PM   #3
Originally Posted by JazMan View Post
Hi Mummy,
Jaz
Nice to see you here too jazman, giving your expert advice.
Thank you for your help. I am going to use mapei thinset for glass mosaic tiles, which is what I am installing. It is white, and I am using a 3/16 inch v notch trowel, (did I use the right technical term.....) as per Bud's advice. I could not find the 1/8 inch square notch trowel, so I went with his second choice.
Is it just my tiles, or are these mosaic tiles not exactly placed straight. What I mean is, the space inbetween the small one inch tiles is not exactly the same on all of the tiles.
Thanks again jazman.
Old 11-19-2010, 09:09 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 412
They're not gonna be mounted perfectly, part of the charm. Are the tiles mesh mounted, paper faced or ? Are the tiles translucent or opaque? You can't go wrong with Bud's 2nd choice.
Jaz
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 05:38 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
