Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-24-2012, 09:31 PM   #1
thin set
the ratio says 4 1/2 qts thin set to 1 1/2 qts of water, i need to divide by 3 and i cant fiqure it out. bad at math
renda is offline   Reply With Quote
Old 12-24-2012, 09:47 PM   #2
thin set
1-1/2 Qt. to 1/2 qt.
4.5 devided X 3 = 1.5
1.5 devided X 3 = .5
Old 12-26-2012, 03:41 PM   #3
Tileguy
JazMan's Avatar
thin set
Renda,
Where did you find that formula? Most bags I've seen tell you how much water to the 50Lb. bag, not by volume.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 12-28-2012, 05:33 PM   #4
yummy mummy's Avatar
thin set
Just go by feel.......always works.......lol
yummy mummy is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
Thin insulation material needed Rav Insulation 6 01-04-2012 05:06 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
thin set removal from hardwood floor Dhays Flooring 1 10-26-2010 04:03 PM
Thin set vs mastic/glue for ceramic tile ph3iron Flooring 6 02-17-2009 08:56 AM
