Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-20-2012, 03:53 PM   #1
thin set
how much thin set do you use when laying ceramic tile on a floor?
dsurace is offline   Reply With Quote
Old 06-20-2012, 03:56 PM   #2
Super Moderator
thin set
That depends completely on the size of the tile---
What are you setting and what thinset? What kind of tile backer is on the floor?
Old 06-20-2012, 04:59 PM   #3
JetSwet's Avatar
thin set
We need more info then that please.
JetSwet is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 48 05-14-2013 10:43 PM
Thin insulation material needed Rav Insulation 6 01-04-2012 05:06 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
thin set removal from hardwood floor Dhays Flooring 1 10-26-2010 04:03 PM
Thin set vs mastic/glue for ceramic tile ph3iron Flooring 6 02-17-2009 08:56 AM
