Superglue - Ceramic Tiles - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 01:42 PM   #1
I have stuck a hook to my bathroom tiles with superglue. I now want to remove hook how do I go about please it without damaging tiles. Thank you.
JanHas is offline   Reply With Quote
Old 10-15-2010, 02:55 PM   #2
Rewards Points: 1,010
Try some nail polish remover. Use a small amount, like on the end of a q-tip. The acetone in the remover should take care of the superglue, but I don't know for sure if it will affect the finish on your tiles, so you might want to test a small inconspicuous area first.
spaceman spif is offline   Reply With Quote
The Following User Says Thank You to spaceman spif For This Useful Post:
JanHas (10-15-2010)
Old 10-15-2010, 03:05 PM   #3
47_47's Avatar
Rewards Points: 44
Superglue holds very well in tension, not in torsion. Give the hook a twist and it should come right off. Use nail polish remover or acetone to remove the residue. As spaceman spif stated test the solvent in an inconspicuous spot first.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
JanHas (10-15-2010)
Old 10-16-2010, 11:20 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
If you try nail polish remover read the ingredients. Some will list water first, which means it is watered down. Some will be non-acetone based. You want one that has acetone as its main (or only) ingredient.
Old 10-17-2010, 03:11 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The acetone won't hurt the tile at all, it may however melt the hook. Try twisting (not pulling) the hook. I have seen super glue cause the tile surface to break when pulling on it.
XXX
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 10:31 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
stains on ceramic tiles bubby :-) Tiling, ceramics, marble 1 06-24-2009 02:05 AM
Some of my ceramic tiles have no glaze abaker30 Flooring 2 03-13-2009 08:44 PM
Difference between difference ceramic tiles J187 Building & Construction 6 03-04-2009 01:17 PM
