Subfloor Thickness For Tile - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By TheBigPig
Old 01-09-2017, 06:22 AM   #1
Alright Guy
Rewards Points: 94
Subfloor Thickness for Tile
My 2x10 joists are spaced 16" OC in an ~8'x8' area. I plan on using 3/4" plywood glued and screwed to the joists every 8". Thinset with a 1/4" CBU on top of it screwed every 8" in both directions. Thinset and tile.
Is 3/4" plywood subfloor adequate for this application? What is preferred/stronger, plywood or OSB? Everything else above sound right?
Also, if I need the height, anything wrong with using a 1/2" CBU for floor applications?
TheBigPig is offline   Reply With Quote
Old 01-09-2017, 10:15 AM   #2
Rewards Points: 658
Re: Subfloor Thickness for Tile
What's the unsupported span of the joists?
stick\shift is offline   Reply With Quote
Old 01-09-2017, 12:32 PM   #3
Alright Guy
Rewards Points: 94
Unsupported span is 91" between load bearing wall on each side.
Old 01-09-2017, 01:22 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
OK, joists' span is fine even without knowing their species or grade. If the " ply you're planning is 'subfloor grade', you're good for ceramic tiles. Some people think Advantech OSB subfloor is better, both are good.
You are free to use " CBU if you need the height. Alternatively you could install ⅜" ply and " CBU or drop the CBU and use ⅛" Ditra instead. What type/size tiles are you planning?
Jaz
Old 01-09-2017, 01:45 PM   #5
Alright Guy
Rewards Points: 94
Going with a 1" hexagon (honeycomb) mosaic mounted on mesh in 10 x 12 sheets.
What exactly is "subfloor grade" plywood? It looks like the AdvanTech is available in my area. I'm not too worried on price here, I just want whatever is best. Is gluing and screwing to the joists correct, with deck screws?
If I stack plywood (3/4 with 3/8) or even 1/2 with 1/2, do I glue and screw, or just screw?
I'm not opposed to using Ditra, but I have had success using 1/4" CBU in the past, so was planning on it again.
Old 01-09-2017, 03:01 PM   #6
Alright Guy
Rewards Points: 94
Looked into the Advantech a little more and I think I'm sold on it. Thanks for the help
Old 01-09-2017, 03:13 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
Advantech is very good. Follow their directions.
I still don't know if it's ceramic or stone.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
abrowning (01-16-2017)
Old 01-09-2017, 03:56 PM   #8
Alright Guy
Rewards Points: 94
Sorry Jazz, it's a ceramic. Any other advice is appreciated. I plan on keeping the subfloor about 1/4" away from the wall studs on all sides, using a polyurethane construction adhesive as suggested by advantech and deck screws.
Old 01-09-2017, 04:26 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
Deck screws, they say to use screws?
Jaz
Old 01-09-2017, 04:28 PM   #10
Alright Guy
Rewards Points: 94
The video on their website specifically says that screws are preferred over nails
Old 01-16-2017, 05:57 AM   #11
Alright Guy
Rewards Points: 94
I ended up using the Advantech. The T&G fit together nicely and the screw pattern was a nice bonus. Glued and screwed, the floor feels really solid.
JazMan likes this.
