SubFloor Prep And Ceramic Tile Installation - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-11-2014, 11:31 PM   #1
Rewards Points: 37
SubFloor Prep and Ceramic Tile Installation
Hi,
Thanks for a very informative forum. I am about to install my tile (ceramic or porcelain) in my powder room and kitchen.
Our home was built in 1999 (about 15 years old); we are located in Cherry Hill, NJ. And we just bought the house about a month ago, so I hope to finish the job before we move in around the end of June.
I ripped off the linoleum / vinyl on the existing plywood subfloor. But as the pictures below show, the vinyl left some sticky residue on the floor, and I am not sure how to remove it. So my first question is what can I use to remove the sticky vinyl residue? Is it advisable to use vinyl adhesive removers? How clean does it have to be - until I see most of the grain of the naked/bare plywood?
I plan to install some 1/4 inch hardi-boards on the subfloor before installing the tiles. Do need to beef up the SubFloor with a luan before installing the hardi-boards?
I've included some pictures of the current floor, including the joists, taken from the basement ceiling for your review.
I appreciate your thoughts and suggestions.
Thanks very much - Oyiwaa
SubFloor Prep and Ceramic Tile Installation-floorjoists.jpg   SubFloor Prep and Ceramic Tile Installation-kitchenfloor.jpg   SubFloor Prep and Ceramic Tile Installation-20140611_160504.jpg   SubFloor Prep and Ceramic Tile Installation-20140611_160524.jpg
Oyiwaa is offline   Reply With Quote
Old 06-11-2014, 11:40 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Before you gorge yourself with a lot of useless and wrong information from the Internet...listen up.
There is no need to remove the glue if you are going to cover the floor with Hardibacker anyway so get that out of your head.
The Hardibacker MUST be installed in a fresh bed of thinset also.
Forget about the luaun thing. Have no idea where you got that nonsense but luaun is the absolute worst thing you could use anywhere in a tile installation. Luaun has never "beefed up" anything but a bond fire.
You should also know that Porcelain tile IS ceramic tile.
XXX
Old 06-11-2014, 11:44 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those structural members are not floor joists, they are floor trusses. There is a difference.
Next thing we need to know is the measurement/length of the unsupported floor trusses.
What is their spacing?
How thick is the subfloor material that is there and is there only one sheet of subfloor?
Is the subfloor tongue and groove material.
Let's go...we can have this over with in about thirty minutes.
XXX
Old 06-11-2014, 11:50 PM   #4
Rewards Points: 13,300
Luan is not a suitable underlayment for any flooring.
No 1/4 wood underlayment should ever be used under tile.
What's the spacing on those truss floor joist?
How thick is the subflooring?
If there spaced 24" or more apart and there's only 1 layer of 3/4 plywood as a subfloor then your looking at having to add a layer of 1/2" A/C plywood over it making sure to not have the seams line up with the seams below.
Doing this is going to require you to remove the lower cabinets. If not your not going to be able slid in the dish washer.
Old 06-11-2014, 11:52 PM   #5
Sorry to repeat your comments Bud, my space bars messing me up and slowing me down.
LOL
Old 06-12-2014, 12:06 AM   #6
Rewards Points: 37
Thanks for your prompt response .... and I've learnt a lot already -- goodbye luaun.
Now ... to your questions:
-- As far as I can tell, there is only one subfloor - the plywood. The vinyls were glued directly onto them (with some sort of whitish underlayment).
Secondly, how do I do those measurements:
-- length of unsupported trusses
-- spacing of unsupported trusses
Thanks - Oyiwaa
Old 06-12-2014, 12:06 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 310
Ah..... I'll bet you say that on all the forums you've posted this Q.
You've received great info here, please answer the questions you've been asked.
Jaz
Old 06-12-2014, 12:14 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks - Oyiwaa
Your trusses rest on a wall at one end as seen in the picture. How far does that truss go before it rest on something? It could be a beam, it could be another wall.
What is the measurement between the trusses?
Forget the whitish stuff, it means nothing. It is probably the felt from the back of the previous floor covering. Is it sorta fuzzy?
XXX
Old 06-12-2014, 12:15 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
LOL
Not a problem - two heads are always better than one. (Usually)
XXX
Old 06-12-2014, 12:17 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oyiwaa,
We are going to first determine if what you have to work with is suitable for a tile installation. I can tell you it probably is not in its current state. Let's get the measurements and we'll know more then. It is all do-able tho.
XXX
Old 06-12-2014, 12:20 AM   #11
Rewards Points: 37
Haaa ... it is a small world, indeed !!.
Thanks - I will take note of all the help here too ...
cheers, Oyiwaa
Jaz
Old 06-12-2014, 12:23 AM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
cheers, Oyiwaa
You will be less confused if you zero-in on one forum and work with them instead of loading up on a bunch of information you may never sift through.
XXX
Old 06-12-2014, 12:30 AM   #13
Rewards Points: 37
Ok .. I will stick by here.
Old 06-12-2014, 12:41 AM   #14
Rewards Points: 37
One more question -- am I measuring the trusses under the specific floor I plan to work (i.e, trusses supporting bathroom floor, separately from those supporting kitchen floor)?
cheers, Oy
Old 06-12-2014, 12:51 AM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
cheers, Oy
They should all be the same basic measurements throughout the house. If they aren't we can discuss it.
XXX
Which is ideal for cement board and ceramic tile installation Shawn49424 Flooring 14 01-23-2013 05:01 PM
Ceramic plank tile installation question = More Difficult than standard tile? gtothek Tiling, ceramics, marble 9 10-05-2012 08:53 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
