Sub Floor Questions.... - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 02:37 PM   #1
K.M.G's Avatar
Rewards Points: 119
Hi
The Home Was built in 1989
I'm planning on Re-doing the Bathroom
I'm using schluter ditra with 13x13 unicom starker porcelain tiles
The Sub-floor is only 1/4(Plywood-OSB Board)Can't tell because from in the Basement looks like OSB board but in the bathroom looks like Plywood
It squeaks in some parts,also the Idiot that put the floor down missed the Joist like crazy.
What do I use OSB TG or Plywood TG ,what is the minimum thickness I need to lay down to Code for Ontario CDN.
Do I rip the old 1/4 up or try and screw it down and place the new OSB Board or plywood down over that.
I heard something about glue but don't know if it's Wood Glue or liqiud nails
What do I need to do with the Joists for support too....
Also the Toilet drain do I cut that out and re-install later or just leave it and use 2-3 Wax rings when putting the toilet back down.
Any help would be great
K.M.G is offline   Reply With Quote
Old 08-30-2009, 04:37 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Your floor may be OSB topped with 1/4" luan
Here are some links to DIY Bathroom Remodel
http://www.diychatroom.com/search.php?searchid=946475
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-01-2009, 11:08 AM   #3
K.M.G's Avatar
Rewards Points: 119
Well thanks for the info
But that link doesn't work
Do you know if 3/4 plywood should be use or OSB 3/4 joists are 16" on center.
Also do I remove the floor or just lay the new PD/OSB over top
Old 09-01-2009, 04:50 PM   #4
Tool Geek
PaliBob's Avatar
Sorry, try this Link:
http://www.diychatroom.com/search.php?searchid=949643
Note this is from a search of the DIY Chatroom using "Bathroom Remodel" as the keyword(s) in 'search titles only' This link will only last a short time, so I would suggest that you save a screen shot of the titles or just repeat my search. There are a lot of good tips in those topics.
First rip out all that OSB, lots of Bathroom Floors are OSB but the strongest floor that I have used is Sturd-I-Floor:
http://napleslumber.com/catalogs/bro_gp_toughply.pdf
Before tile I would top it with "Red Guard"
http://www.idealtruevalue.com/servlet/the-138757/Detail
Disclaimer
& Stay Safe
.....Bob Lavery
