Small Pieces Of Backerboard - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 11:40 PM   #1
Rewards Points: 97
Small Pieces of backerboard
I am installing a new granite countertop over the holiday and have a question about how to install these small pieces of hardie board. IT is 1/2" thick and about 1.25" inches tall.
I tried using hardie board screws and it broke in half. I also tried using some roofing nails I had with the same result
should I try drilling pilot holes through the backerboard so it goes through no problems???
here is what i am trying to do
Small Pieces of backerboard-imag0217.jpg   Small Pieces of backerboard-imag0218.jpg   Small Pieces of backerboard-imag0219.jpg
BigRedFan is offline   Reply With Quote
Old 11-21-2012, 11:41 PM   #2
Rewards Points: 97
my other idea is to just apply the mortar directly to what is already there although i would prefer to not go that route as IT is not correct
Old 11-22-2012, 01:01 AM   #3
did you try predrilling the holes for the roofing nails?
Old 11-22-2012, 06:57 AM   #4
DIY staff
Rewards Points: 7,174
Are you simply using that as a sub base for a slab?
If so the cracked backer should bot affect the slab---you did not mention the brand of backer board---Hardie is difficult to set and frequently had issues with protruding screw heads----I use Wonder board or Durrock.
Old 11-22-2012, 08:51 AM   #5
Rewards Points: 97
Those pieces will have 1.5 inch pieces of granite attached to them
Old 11-22-2012, 09:38 AM   #6
DIY staff
Finish attaching the backer--set the slab in a bed of thinset and you will be fine---
Next project use Wonder board--
Feedback on Small Project Service darrelsumi Interior Decorating 4 11-12-2012 09:33 PM
Is it proper to tile over chipboard if backerboard is first laid? wvueers2004 Flooring 7 10-13-2010 06:22 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 06:11 AM
I want to pour a small slab... Any pointers? Alan Building & Construction 2 04-17-2010 06:46 PM
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 02:52 PM
