-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Small Pieces of backerboard (http://www.diychatroom.com/f84/small-pieces-backerboard-164343/)
BigRedFan 11-21-2012 11:40 PM
3 Attachment(s)
I am installing a new granite countertop over the holiday and have a question about how to install these small pieces of hardie board. IT is 1/2" thick and about 1.25" inches tall.
I tried using hardie board screws and it broke in half. I also tried using some roofing nails I had with the same result
should I try drilling pilot holes through the backerboard so it goes through no problems???
here is what i am trying to do
BigRedFan 11-21-2012 11:41 PM
my other idea is to just apply the mortar directly to what is already there although i would prefer to not go that route as IT is not correct
DannyT 11-22-2012 01:01 AM
did you try predrilling the holes for the roofing nails?
oh'mike 11-22-2012 06:57 AM
Are you simply using that as a sub base for a slab?
If so the cracked backer should bot affect the slab---you did not mention the brand of backer board---Hardie is difficult to set and frequently had issues with protruding screw heads----I use Wonder board or Durrock.
BigRedFan 11-22-2012 08:51 AM
Those pieces will have 1.5 inch pieces of granite attached to them
oh'mike 11-22-2012 09:38 AM
Finish attaching the backer--set the slab in a bed of thinset and you will be fine---
Next project use Wonder board--
