Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 03-12-2011, 11:28 AM   #1
Small bathroom tile design
We have a small bathroom that needs new flooring installed. We are thinking about 12" tiles laid in a diamond pattern. We are considering having an inset of 1"tiles (maybe 3 or 4 wide) as a border near the center of the room but are afraid it will make the room look smaller.
The room design looks like it can handle it if it doesn't make it look too small
Is that design recommended for small bathrooms?
Swinks is offline   Reply With Quote
Old 03-12-2011, 01:08 PM   #2
Tileguy
Bud Cline's Avatar
Anything goes. If you like the idea go for it.
Old 03-12-2011, 03:02 PM   #3
firehawkmph's Avatar
Swinks,
Something like this? These were 12" tiles with the corners clipped on every other joint with four one inch mosaics for accents. This room was a couple inches out of square with some supposed to be 45 degree angled walls. The only thing with running the tiles on a diagonal is that if your walls are out, it shows up more on your triangle shaped pieces.
Mike Hawkins
Small bathroom tile design-img_5251.jpg   Small bathroom tile design-img_5250.jpg
firehawkmph is offline   Reply With Quote
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Small, very small bathroom exhaust fan stubits HVAC 3 04-06-2010 02:52 PM
Subfloor base for bathroom tile StevePax Remodeling 6 12-23-2009 10:41 AM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 07:18 PM
