SLC On Plywood Or On Backerboard? - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 01:31 PM   #1
SLC on plywood or on backerboard?
Am getting ready to tile our laundry. I believe (haven't confirmed yet because its currently covered by the dryer) that one corner has a small area that may need to be leveled.
If needed, is it better to lay (thinset and screw) the backer board, then use some sort of SLC on the backer board? Or use the SLC on the plywood, then backer board?
I'm pretty sure the area would be pretty small, and I'm not sure how adding lath etc then SLC would work in such a small space.
Thanks,
Kiwi.
Kiwi. is offline   Reply With Quote
Old 04-19-2011, 04:31 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 2,886
Hi,
Backer board then self leveling or patch. Not a good thing to nail/screw into concrete patching material.
Jaz
Tile 4 You LLC Troy, MI - Consulting by phone/internet -PAYPAL
DITRA Installs - KERDI Watertight-Mold-Free Showers. I have NEVER made a mistake, I thought I did ONCE, but, I was WRONG! A+ BBB rating - est. 1987 - over 50 yrs. exp.
JazMan is online now   Reply With Quote
Old 04-19-2011, 07:26 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 3,048
Why use backerboard to begin with?
The Self Leveller is the backer.
XXX
Old 04-19-2011, 07:51 PM   #4
Tileguy
JazMan's Avatar
Good point, but, sounds to me as only a small area needs leveling. If it ends up that the entire floor is covered with the proper thickness of SLC, then that's all that's required.
Jaz
Old 04-19-2011, 08:07 PM   #5
Tileguy
Bud Cline's Avatar
Yow I see what you mean:
Missed that part, I was thinking the whole room was getting levelled.
There would be less costly ways to flatten out that floor other than SLC at $30 per bag and primer at $15 a jug. Doesn't sound (now) like fifty pounds of SLC would be required.
XXX
Old 04-20-2011, 09:59 AM   #6
Thanks for the replies. It is only a small amount that may need to be levelled and I haven't really investigated it, so you never know, it may be flat! Will be a little annoying to spend $50 to fix such a small space, but I guess you need to do it right.
Old 04-20-2011, 05:09 PM   #7
Tileguy
Bud Cline's Avatar
I think you can buy a 25# bag of Portland cement-type floor patch for under ten bucks and fix it with that. Even then, the "fix" would go on top of the cement board.
XXX
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Does the plywood have to come out? AGH! JP6044 Tiling, ceramics, marble 7 01-31-2011 12:20 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Advice on using Ditra on Plywood against Backerboard fjlcisco21 Flooring 5 08-10-2009 06:56 PM
