Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 10-24-2009, 06:35 AM   #16
Default wait a minute, if i just put cross beams from joist to joist, it sounds like my
initial idea. Maybe the board I put across the joists should be held up by some cement blocks or something. I;m just thinking that with adding more boards sistering or going across, I'm really adding more weight to the primary ones when weight is what I'm worried about. Does that make sense?
brenda o is offline   Reply With Quote
Old 10-25-2009, 03:07 PM   #17
Nope, makes no sense.
Just adding a cross beam on cement blocks on just the ground won't work either, you need a footing if this is just the ground under the home.
R&D Tile is offline   Reply With Quote
Old 10-26-2009, 02:42 AM   #18
Default ok, i'll get under there and look more closely at
what I'm working with. I'm going to have to go with sistering the joists I have. I don't want my floor to start sagging and tiles break so thanks for the know-how again! Back to the lumber yard
More On This Topic
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. In most cities, you'll be required to pull a permit, when finishing your basement. If you maintain open communications, with the city, they'll be able to... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The budget is very important because that gives you an accurate idea of how much you're going to spend on the project and that way you can stay within that... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Remodeling a basement can be a big task. When you want to remodel your basement, you first want to think about how big it is and what you want to do, with... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
[IMG] code is Off
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 09:58 PM
Slate tile thekctermite Flooring 11 05-02-2008 09:31 PM
Slate Tile... Jshakour Flooring 13 04-25-2008 12:34 AM
Plasma TV over Slate jrcrum Home Theater 4 08-27-2007 03:01 PM
Outdoor Slate Question (with pictures) kabbak Flooring 2 07-05-2006 05:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
