Slate Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 12:36 PM   #1
Rewards Points: 204
Slate question
Has anyone used slate tile for the shower walls? Is it ok to use? If not what is recommended for showers?
Thanks, Abs
Abs777 is offline   Reply With Quote
Old 06-03-2011, 01:30 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Check out this thread:
Slate tile in a shower
Old 06-06-2011, 03:28 PM   #3
ccarlisle's Avatar
Yup. Yup. Sure.
Depends entirely on your installation and maintenance budget.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 06-09-2011, 08:33 AM   #4
Rewards Points: 204
Thanks guys for the info. I am a little scared of using it and it's seems like it will be more work to up keep. I will probably just go the ceramic or porcelain route. When doing wall tile is there a special mortar\thinset that you need to use to help it adhere to the backerboard?
Old 06-09-2011, 10:52 AM   #5
ccarlisle's Avatar
This may be a wise move; as others have intimated elsewhere, slate is a wide description of a stone, much like the word 'granite'...both can mean widely different things to different people, but the common, everyday term is somewhat misleading. Slate is OK for a shower - but only the best kinds of slate, from nearly where I am. Even then, maintenance becomes a huge issue that may people overlook...
If your budget is unlimited and you have the occasional help around the house to do the daily maintenance on your $25,000 slate shower, then go ahead and enjoy yourself. But most people don't have those assets to put aside just for cleaning your body in the morning, so the better route for those pople is exactly the one you chose.
The Following User Says Thank You to ccarlisle For This Useful Post:
Abs777 (06-09-2011)
Old 06-09-2011, 10:55 AM   #6
Rewards Points: 204
Yeah, I for SURE don't have that kind of budget. If I had that kind of money I would invest it wisely in women and alcohol.
I feel better about this decision now, thank you.
Old 06-09-2011, 11:10 AM   #7
ccarlisle's Avatar
Yeah, me too.
I have seen and repaired such showers so I know a wee bit about it. And for sure you won't regret this decision. Yet there are some people who just can't live without the 12-nozzle, overhead pressure jetted, gold leaf taps and the room-sized slate/marble/limestone showers that take an army of cleaners/restorers and stone pros to upkeep. But if you read any of the plumbing bbs you see that thiose who mistakenly put in a slate shower without knowing all about slate showers, usually regret it. Kid you not.
Advice on Travertine and Slate subfloor spo100 Flooring 2 09-08-2009 07:52 AM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 04:00 PM
changing from slate to asphalt and can I ventilate? Mahnrut Roofing/Siding 2 03-26-2009 09:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
