Slate Fireplace - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 03:15 PM   #1
Slate Fireplace
I want to redo the tile around my fireplace. Currently, it has a black marble tile and I want to replace it with Slate and also add Slate to the surrounding areas that currently do not have tile.
I am assuming it's best to REMOVE the current marble and then use thinset to lay the new slate. Someone told me to leave the marble and tile ON TOP of it. I was skeptical.
Do I have to do anything unique on the wall part?
Any ideas or suggestions?
JackOfAllTrades is offline   Reply With Quote
Old 09-20-2009, 10:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You may be able to tile-over the marble. Seriously scuff the marble (I'm sayin' ruin it big time) then use a modified thinset to set the slate.
The untiled wall areas shouldn't be a problem. There again, if they are painted, scuff'em and go for it.
XXX
Old 09-21-2009, 07:58 PM   #3
I removed the bottom portion of tile because if I tiled the slate over it, it would make the tile height too high.
SEE ATTACHMENT
Should I just remove the remaining sheet rock and replace it with another backerboard by screwing it to the plywood underlayment that is showing?
SEE ATTACHMENT
The area above the fireplace has the marble tile still attached. It is deeply recessed, so I can leave the marble tile that is there and just tile OVER IT with the slate, correct?
What type of thinset should I use for that area?
Old 09-21-2009, 08:31 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
First of all that tile looks like granite to me not marble.
Why?
Correct.
Use a thinset rated for natural stone.
XXX
Old 09-21-2009, 10:30 PM   #5
Why?
Your probably right, it is granite.
As to why I would rip out the remaining drywall at the bast of the fireplace. In the picture where it shows the ripped up drywall. I removed the tile and it pulled the drywall with it. So I wanted a flat and secure base to install the new slate.
The fireplace sides will be left alone, no demo, just attaching slate to it. It was the base of the fireplace area that I removed the drywall because it ripped up sections when I removed the tile.
Old 09-22-2009, 01:14 AM   #6
I got a bag of the Mapei UltraFlex II.
When it states "properly primed gypsum", what do they mean?
I have 5/8" fire rated drywall that is screwed down to a plywood base. This is around the fireplace area. Does this mean I have to "primer" the drywall prior to using the thinset over it?
Old 09-22-2009, 08:40 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Tile adhesives won't stick to an abundance of drywall joint compound. This relates to drywall inside/outside corners and seams. You shouldn't have any of that and shouldn't require any primer if you are working with pristine drywall.
XXX
Old 10-01-2009, 07:12 AM   #8
Well, here is the BEFORE and AFTER pics. Thanks to all who helped with the technical info and advice!
Old 10-01-2009, 09:28 AM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Awesome!
XXX
Old 10-01-2009, 03:25 PM   #10
Awesome!
Thanks. I don't own a wet saw, so I had to measure and take each piece to LOWES to have them cut. I've only laid tile about 6 times, so I am still a "rookie".
Old 10-01-2009, 04:41 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They can always use the practice.
XXX
Old 01-03-2010, 02:10 AM   #12
Final update with artwork displayed (Alaskan).
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 05:59 PM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 05:58 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
