Siliconized Sanded Grout Disappointment - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 09:19 AM   #1
siliconized sanded caulk disappointment
I built an outdoor tiki bar table. The top is ceramic tile over 3/4 inch pressure treated plywood. I used thinset to adhere and researched and found siliconized caulk to be the likely answer in place of grout as the table will reside outdoors, and it should remain flexible. I've worked with grout and caulk before, even silicone caulk. This was a nightmare. It tooled like complete crap. I'm disappointed as it was going well until this step and now it looks like it was done by a complete novice. (which I am.... Perhaps I'm just being overly critical, but can I remove it now? Would an unsanded been easier to tool? I don't want it shiny. Do I even have any options at this point?
Whimsy101 is offline   Reply With Quote
Old 07-10-2012, 07:57 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi,
The caulk will be the least of your worries, I believe. By rights that project is not gonna last very long I'm afraid to say. Is this ceramic tile a true porcelain? I imagine you used a modified mortar?
You should not have used pressure treated ply, plus you needed a concrete backer too. You do not use pressure treated for anything like this. Not sure what good pressure treated plywood is for.
Jaz
Old 07-14-2012, 09:41 AM   #3
I'm afraid there is some merit behind his concerns..
http://www.groutrevive.com
grevive is offline   Reply With Quote
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
Sanded Grout boomer7 Flooring 0 10-21-2011 12:43 PM
Using sanded grout for spaces less than 1/8"? sukhenkoi Kitchen & Bath Remodeling 7 05-20-2011 04:51 PM
Can i apply unsanded grout over sanded grout? Philj Tiling, ceramics, marble 1 04-19-2011 07:58 PM
Sanded grout for 1/16th space Kuuyku General DIY Discussions 5 07-05-2008 09:29 AM
