Shower Walls For Seasonal Cottages - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 10:39 PM   #1
shower walls for seasonal cottages
hello
looking for some advise on the right product to use or not to use when doing the shower walls in a 3 season cabin/cottage, unheated in the winter, so it goes way below freezing.
what is going to stand up the best to the freeze thaw cycle.
typically we will not be there during full winter so in the late fall once it freezes up it will stay that way till early spring, and consequently a slower transition from each extreme. no foundation either, just on blocks so the building quite likely moves a bit.
I have been looking at installing premolded shower walls such the
polystyrene units but i have heard they do not like the cold,
acrylic wall units which are more expensive but apparently more durable.
I have seen 4x8 sheets x1/4 of what looks like acrylic or lexan
also thinking about tiling and using concrete board as a backer. I have tiled before but not in a freeze thaw environment.
I suspect any of the wall surfaces will do fine as long as the right product is used to attach it to the walls, ie silicone, mastic, glue, mortar, thin set or grout. Something that will either be somewhat flexible and move with the temperature changes, or be rock solid and unaffected.
any advise from someone who has been there and done that.
experience is a wonderful teacher, I just don;t want to get a fail on the first attempt.
thanks for any input you can offer.
goshdarn is offline   Reply With Quote
Old 01-25-2014, 10:41 PM   #2
Rewards Points: 6,652
It really depends on how cold the interior gets.
Old 01-25-2014, 10:52 PM   #3
really cold,
Manitoba, cold -40C, and if your south of the border that is still -40 F
it will basically drop well below freezing in nov and stay that way till late feb.
since the cabin is insulated, once it freezes up it will stay that way till mother nature decides otherwise.
Old 01-25-2014, 11:30 PM   #4
Does not matter where you are right now, it is cold all over. And actually it is warmer in Northern parts of Canada right now, then it is down in our area.
Really though, any place if you plan on not heating it when not occupied, is going to end up with mold or mildew in it, if it is allowed to get to freezing temps. Any moisture in the building, from the weather changes heating and cooling that place, will cause any type of material to fail.
Just go with the PVC panels glued on the wall. But really if you Winterize the place and shut all heat and electricity when not there, you will find issues when you go to open it back up, that will need to be fixed.
Right now, the coldest place in Northern Canada is Resolute. It is -36f with a feels like of -64f. http://www.weather.com/weather/tenda...aps.google.com Now that is cold. The coldest place on the planet right now is Dudinka, Russia. It is -57f with a feels like of -57f. http://www.weather.com/weather/tenda...aps.google.com
Old 01-26-2014, 03:28 PM   #5
thanks for recommendation of the pvc panels, they do seem the simplest solution at present. with expansion joints hopefully they will do fine.
never had a problem in over 32 years with mold or mildew. have done 3 different renovations since original build in 82 and all is well. we are in a community of 500+ other cabins all of which are shut down for the winter.
Even the drywall has survived nicely until i releveled 2 years ago. and that is just some minor joint work.
Old 01-26-2014, 03:35 PM   #6
DIY staff
Rewards Points: 7,174
I've never had trouble with a properly set tile shower in an unheated cabin---just make sure you use powdered thinset---no organic mastic--
Old 01-26-2014, 05:27 PM   #7
thanks mike, that is good to know, I would sooner have the tile any way, it is no more expensive than the surrounds, more work maybe but i think looks better.
Old 01-26-2014, 05:32 PM   #8
DIY staff
I agree---one small thought---you might consider using a bath tub mixer with a spout---handy for washing beach sand off the feet--and they will self drain the shower arm---Not an issue if you open the valve when you are draining your system,however.
gregzoll (01-26-2014)
Old 08-03-2015, 04:09 PM   #9
Rewards Points: 2
showers units in unheated cottages
We were looking to purchase an acrylic shower (which has a fibreglass backing) and spoke to the manufacturer, A&E Bath of Quebec, re this. We were told that it is a bad idea to install such a shower in a Nova Scotia cottage that is unheated in winter, and that they have already had three reports of customers' acrylic shower walls cracking (that were screwed to wood walls). Their warranty does not cover such cracks. We were told to purchase an ABS shower, as ABS will not crack in winter.
Does anyone have any comments on this please?
charles7302 is offline   Reply With Quote
Tags
freezing , seasonal cabins , seasonal cottages , showers
lay out of tiles on shower walls GBH1 Plumbing 2 02-06-2013 08:30 PM
gap patch between shower walls morequestion Tiling, ceramics, marble 4 02-06-2013 05:14 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
greenboard on custom shower walls wvgreg General DIY Discussions 13 09-20-2009 03:31 PM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
