-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Shower tiling question (http://www.diychatroom.com/f84/shower-tiling-question-188264/)
detroittigerfan 10-08-2013 12:50 PM
Hi,
When you have an exterior wall in your shower and you plan on using kerdi membrane over the cement board do you eliminate any faced part of the insulation of poly sheeting over studs on the exterior wall?
JazMan 10-08-2013 04:54 PM
Tiger fan,
I think if you're tiling and Kerding all the way to the ceiling, it's a good idea to just slash the vapor barrier of the insulation. Never use poly or tarpaper on the studs when you're applying a surface waterproofing product such as Kerdi, matters not if it's an inside or outside wall.
Good plan to go with Kerdi waterproofing, are you also tiling the shower floor and using a Kerdi Drain?
Jaz
detroittigerfan 10-08-2013 04:58 PM
Originally Posted by JazMan (Post 1251171)
Tiger fan,
Jaz
Yes now what about if i use kerdi on the shower ceiling should I still keep that kraft faced batts that are there now?
JazMan 10-08-2013 07:08 PM
I would do the same. Slash the paper.
Is this a steam shower? Do you really think you need it on the ceiling?
Jaz
detroittigerfan 10-08-2013 07:44 PM
Jaz
Well leaving drywall on the ceiling in a shower is that smart?
JazMan 10-08-2013 08:13 PM
In many situations it's alright, but I'd tile the ceiling too especially if there's a drop in the doorway that might hinder steam from escaping. It also depends on how the shower is used. Do you have and use the exhaust fan? If you have teenage girls, Kerdi and tile everything.:thumbsup: And make sure you run the fan for at least 10-15 minutes after you're finished.
As you know by my signature line, I like and use Kerdi all the time.:thumbsup: Schluter recommends applying Kerdi to about the height of the shower head, for standard showers. But, the more the better. Personally I'm not crazy about installing Kerdi overhead.:eek: You might consider a liquid membrane for the ceiling.
The Kerdi system is fantastic, but its best feature is the Kerdi Drain and how the bottom is built. That is why I asked about how the floor is being built.
Jaz
Gary in WA 10-09-2013 09:03 PM
Originally Posted by detroittigerfan (Post 1251113)
Hi,
No, (above grade) use it if required by building department. Slashing a vapor barrier does next to nothing, slashing an air barrier is a biggie; read paragraph below Photo 6; http://www.buildingscience.com/docum...ms?full_view=1
The vapor barrier should run to bottom of drywall under the tub, as required by code. This protects the wall below the tub cavity space from moisture- especially needed if any holes to crawlspace/basement. With cement board between two vapor barriers, no worries, unlike wood framing between two vb's, dreaded "vapor barrier sandwich".
You are in Zone 5; http://energycode.pnl.gov/EnergyCode...state=Michigan
That requires a Class 1, or 2, depending on wall perms; http://www.buildingscience.com/docum...commendations/
Please describe the wall make-up....
Gary
