Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 06-02-2009, 01:42 AM   #1
Shower tile specifics re: hair coloring
Much has been written regarding ceramic tile and the subset porcelain tile, but much of that info has to do with durability with floor traffic. My question is about a very specific issue pertaining to tiles in the shower that hasn't been covered.
After a demo and all the appropriate prep, i.e. cement board, sloping shower pan, etc. etc., I want to install tile in our shower. I want to install unglazed porcelain that looks like natural stone, but I have an issue that may prohibit this. As many middle-aged woman in the world today, I color my hair in the shower. The dark auburn color would certainly stain some types of tile. My understanding is that porcelain is vitreous and would not stain. I don't want the glazed tiles if possible because I like the look of the natural stone... I don't want a glossy appearance. Are there any porcelain tiles that are unglazed that will withstand hair color? Thx!
Pammylu is offline   Reply With Quote
Old 06-02-2009, 08:31 AM   #2
Just pick up samples of tiles you like and see if they stain. I have unglazed porcelain tiles in the kitchen an they haven't stained with red wine or anything else. I used an Italian company called Cerdonomous.
But best thing to do is just try out different tiles with the dye.
I think you'll have more of an issue with the grout then the tile.
Set up two tiles with a grout in place between them. Seal the grout with a few coats of sealer, then do the experiments.
The grout will need to be sealed on a regular schedule.
Ron
Old 06-03-2009, 12:28 AM   #3
Tileguy
JazMan's Avatar
Most people think that "glazed" means shiny, it does not. Glazed tiles can be very dull and rough. I agree the grout would be more of an issue, although with the water running I doubt even the grout will stain. Use a beige/brown grout just in case, you'll want a color anyway.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 06-03-2009, 08:56 AM   #4
Jaz
Standing in the shower applying the coloring will get it on the walls, above the water spray area. It then runs down the walls and settles it the grout joints.
Ron
Old 06-05-2009, 03:32 PM   #5
Tileguy
Bud Cline's Avatar
Any porcelain tile will work as good as anything will. Porcelain is the best bet, glazed or unglazed doesn't matter. Use a urethane grout. Even porcelain tiles can be stained slightly so seal the tiles.
Tags
glazed, hair color, porcelain, shower, tiles
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
