Shower Tile Removal - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 12:48 PM   #1
shower tile removal
how do i remove old tiles from floor and walls and cement board removal. i will be installing a new pan how do i do this?
heathermark is offline   Reply With Quote
Old 02-23-2010, 07:38 PM   #2
DIY staff
Rewards Points: 7,174
Removing the shower walls---First peal off the top row of tiles using a heavy bent scraper.
Next peal off the two outside rows.
Install a blade in your Sawsall-Upside down -so you can make a shallow skim cut along the edges of the tile. Be careful not to cut any deeper than the thickness of the board.
Now get a hammer and punch a couple of hand holds and pull--that's about it--
Removing the floor is a hammer and pry bar job,
Shower pan removal--If you can get at the drain from below--cut off the old drain and then just lift out the old pan.
If every thing must be done from above---I use a Skill Saw and make several plunge cuts around the drain--once the pan is separated from the piece that has the drain--
Remove the pan--saw off the drain with a long Saws All blade.
Replace the P-trap and follow the directions that come with your new drain set.
Rather over simplified instructions--You have to figure out some things as you go.---Mike---
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
