-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   shower tile removal (http://www.diychatroom.com/f84/shower-tile-removal-65164/)
heathermark 02-23-2010 12:48 PM
shower tile removal
how do i remove old tiles from floor and walls and cement board removal. i will be installing a new pan how do i do this?
oh'mike 02-23-2010 07:38 PM
Removing the shower walls---First peal off the top row of tiles using a heavy bent scraper.
Next peal off the two outside rows.
Install a blade in your Sawsall-Upside down -so you can make a shallow skim cut along the edges of the tile. Be careful not to cut any deeper than the thickness of the board.
Now get a hammer and punch a couple of hand holds and pull--that's about it--
Removing the floor is a hammer and pry bar job,
Shower pan removal--If you can get at the drain from below--cut off the old drain and then just lift out the old pan.
If every thing must be done from above---I use a Skill Saw and make several plunge cuts around the drain--once the pan is separated from the piece that has the drain--
Remove the pan--saw off the drain with a long Saws All blade.
Replace the P-trap and follow the directions that come with your new drain set.
Rather over simplified instructions--You have to figure out some things as you go.---Mike---
