Shower Tile Question - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-27-2013, 09:38 AM   #1
Hello, My name is Deborah and I don't do DIY anything.
I need some advice. My shower stall is set for tile...right now it has Durarock with the seams covered with thinset...no tile yet. The drain and shower pan...and all that is installed, the tile is the last stage.
I was told by my friend (the installer) that he thinks I can use my shower once the Thinset is dry...he said it's just concrete...It is going to be days before he can get back to finish the tile, and I really could use a shower, I hate sponge bathing.
I'm afraid to mess up his work, and delay the finished shower. Is it okay to use my shower with nothing but concrete and thinset...no tiles?
WattsD is offline   Reply With Quote
Old 07-27-2013, 11:25 AM   #2
Rewards Points: 4,796
Showers are supposed to be waterproof before tile goes in, so theoretically you should be able to use it.
In practice, there are a couple problems. Although tile with grout is not technically a waterproof application, it still does deter water from getting through to a certain extent. If there is any leak at all in your shower in the current state, water will go through, whereas after tiling, it might not (depends on where the leak is). It depends on how good a job the shower builder did.
Second, you don't really want to get anything gunky like conditioner or a bunch of soap building in the nooks and crannies of the cement board. It could harbor mold underneath your tile later.
So other than practical issues, yes you can use a shower before it's tiled.
jeffnc is offline   Reply With Quote
Old 07-27-2013, 12:24 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
Do like we did, cover the Durarock with plastic, we used a cheap plastic tarp, it worked great for us and nothing got wet.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-27-2013, 12:57 PM   #4
Not on the floor though, or you might slip and break a hip.
Old 07-27-2013, 02:09 PM   #5
I live in Illinois. Thank you! You folks made me feel more confident...I used my shower. It was at a perfect pitch not noticeable but left no puddles, the new glass block window also has a ledge (slightly pitched) no puddles left there. It made a perfect shelf for shampoo and liquid soap. The built in seat allowed for water drain off, and also had no puddles. My builder friend did a great job.
I was very carful with shampoo and soap, and after my shower (short one) I rinsed everything down real good, so no residue would be left (I hope) to cause problems later. Thank you for that tip, I wouldn't of thought of it. Nothing leaked at all. It dried up really fast as well.
The tile should go down next week...Thank you again for your help. I will be keeping this site on my favorites, it's like handy man heaven here.
The Following 2 Users Say Thank You to WattsD For This Useful Post:
BigJim (07-27-2013), oh'mike (07-27-2013)
URGENT!need to find the order of putting in a tile shower gailquiler3 Plumbing 6 11-19-2012 08:10 AM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 10:05 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 11:48 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
