Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 11-17-2012, 11:35 AM   #1
Shower tile on drywall
So the tile in the shower stall in my home was built by the previous owner over drywall. There is serious damage up the bottom foot of drywall which I've torn out already. However further up the remaining 5 feet the drywall and tile appears to be fine. I have not demo'd that portion yet. I know drywall for showers is sacrilege but was pondering adding cement board to the bottom foot and retiling over that. Am I crazy or could this work?
pisbouts is offline   Reply With Quote
Old 11-17-2012, 12:00 PM   #2
Super Moderator
It is a patch job---and will look like one----if you can live with that---yes--it can be done if the tile ---backer board seam is under the center of a tile---
If you can afford better than a patch job-----replace the enclosure---waterproof the backer with a membrane---I like Hydroban--Red Guard works well--there are others,too.
Change the shower mixer valve---and you have a shower that will last a long time---------------
Old 11-18-2012, 12:32 PM   #3
Stuck in the 70's
Blondesense's Avatar
This is exactly what I found when I redid our shower. When I tore it out there was mostly greenboard, with cement board under the bottom two rows of tile.
Apparently the previous owner tried this fix. I don't know how long it was like this, but it was leaking badly and the remaining greenboard was full of mold.
If you try it, I would consider it temporary until you can do it right.
Tile around one piece shower unit and tub golfgirl Tiling, ceramics, marble 2 03-09-2010 08:26 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
