Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 01-12-2013, 04:06 PM   #1
Shower tile
Can I use 12"x12" porcelain tile on my shower walls and floor. With 1/8" spacers between the tiles?
Hwymannd is offline   Reply With Quote
Old 01-12-2013, 04:59 PM   #2
Shower tile
Sure, why not?
cleveman is offline   Reply With Quote
Old 01-12-2013, 05:46 PM   #3
funfool's Avatar
Shower tile
biggest problem you will have, getting the big tiles flat and even with each other.
Walls are by nature, not really flat, shower floor by design is sloped to the drain.
Sure you can use 12"x12" tiles, smaller 4"x4" or 6"x6" are more forgiving and easier to set.
For the floor, the small 1"x1" or 2"x2" that come in 12" sheets are really easy to set.
Just the bigger the tile, the more complications you run into.
Same with a kitchen floor, 12" tile is fine, start going to a 18" or 24" tile. floor better be real flat and will take patience to lay them.
Again, using a 1/8" grout line means you better be good, a larger grout line will hide many tile imperfections while being laid ... 1/8" you have no room for error, every bump will show next to the joining tile.
So answer is yes, you can do this .... just be aware of the issues you will face while laying it.
Be patient, take your time .... will come out great.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
oh'mike (01-13-2013)
Old 01-13-2013, 10:00 PM   #4
Tileguy
JazMan's Avatar
Shower tile
12" or even larger on walls are no problem. We have to assume the substrate is flat within standards though. You have to fix most walls these days.
Use tiles that are less than 4" on shower floors unless you build the floor to incorporate a linear drain which has only one plane. Normal traditional shower floors are dished, so no large tiles can be used.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 03:32 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
