Shower Pans - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 11:20 AM   #1
shower pans
I am putting a ceramic shower on a cement floor. I plan on putting a sloped cement floor from 3/4 to 2 inches under the ceramic. My question is why do I need a pan liner? Can I just use cement on cement under the ceramic? It seems that the ceramic should be waterproof. Thanks
gordo1 is offline   Reply With Quote
Old 07-09-2011, 10:48 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 198
Absolutely NOT! Tile & grout is waterproof in that water does not hurt it. That does not make it waterproof so water doesn't get thru.
You need to study and understand how a shower should be built, and why. I would rather see you build a real "waterproof" & "watertight" shower. Kerdi membrane with the Kerdi drain is the answer. http://picasaweb.google.com/tile4youinc
Jaz
experience with TileRedi shower pans? blender Remodeling 5 12-11-2014 05:22 AM
pre built shower pans or custom built? vote4Pedro Building & Construction 6 04-07-2011 10:28 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Concrete Shower Pans??? seaturtle General DIY Discussions 10 01-21-2008 03:26 PM
