Shower Pan - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 09:29 AM   #1
shower pan
What concrete mix should I use for mortor bed
thumpd50 is offline   Reply With Quote
Old 12-27-2012, 09:38 AM   #2
Rewards Points: 14,026
Use morter not concrete mix.
Old 12-27-2012, 11:38 AM   #3
Thanks joe bag mortar there is many choices at menards or Lowe's any suggestions
Old 12-27-2012, 01:02 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 412
Thumpd50,
It's called "Sand Mix" or "Sand Topping Mix". http://www.quikrete.com/ProductLines/SandToppingMix.asp
Ideally the recommended mix/ratio for shower deck mud is 1:4 . This product comes 1:3. Use it as is or add some all-purpose sand to make it a little easier to work with. 1:3, 1:4, 1:5, it'll all work well. Just mix it very dry, tamp well then screed to shape, finally steel-trowel to make it more dense.
Jaz
Old 12-27-2012, 05:06 PM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I just bought this at Lowe's. Read on another forum(Bud Cline) to buy 50 lb bag of Sand topping mix and one bag of 30 lb. all purpose sand gets the right mix. Its by volume not by weight. Buy pairs as needed
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 12-27-2012, 05:37 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 412
Great suggestion there Chris.
I don't think those bags come in #50, but makes no dif. And yes the formulas are by volume not weight. However when you're not mixing it yourself you're left with buying bagged materials and so they are referred to by weight. Easy to figure with a little algebra knowledge, but I've seen it made as lean as 1:7 for floors and still fine.
Jaz
Old 12-27-2012, 09:15 PM   #7
Still going...
ChrisDIY's Avatar
Rewards Points: 508
I have a shower pan to build in the next month. So will be following this thread.
--Chris the DIY Guy
Old 12-27-2012, 09:43 PM   #8
747
registered
747's Avatar
Rewards Points: 534
Your talking about doing a old fashion mud job. Make sure you have slop to center of drain. Its a sand cement mixture with the consistency of motar. This is old school. But the best. Especially on walls. Where you put up the ribwire attached to the studs. You can get the walls perfectly level before tile setting. If i'm not mistake the top coat would be a sand/cement mixture with masonary lime add to it. This has been pretty much replaced with the invention of cement board. On the tile pan. Its pretty much ditra these days.
747 is offline   Reply With Quote
Old 12-28-2012, 12:21 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 412
No, not Ditra for shower pans. You're thinking of Kerdi.
Although I think it's the best, only a small percentage of showers are built with Kerdi membrane and drain.
Jaz
Old 12-28-2012, 02:10 PM   #10
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Is Kerdi approved for steam shower?
Sent from my Samsung Galaxy Tab 2 using DIY Chatroom
--Chris the DIY Guy
Old 12-28-2012, 07:58 PM   #11
747
registered
747's Avatar
Rewards Points: 534
Jaz
Thanks for the correction. I meant kerdi. The Styrofoam pan kit.
Old 12-29-2012, 08:55 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 412
Certainly is, yes.
Jaz
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
