Shower Niche Tiling - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 07:09 PM   #1
Trucon01's Avatar
Rewards Points: 510
Shower Niche Tiling
Hi All,
I have a two-fold question.
1.
When tiling a shower, should you tile the shower niche / insert first or last?
2.
Whenever you do tile the niche, should you tile the back first and then all 4 sides, or tile the back last?
The niche will have horizontal glass tile while the sides will have regular tile.
Thanks.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 05-15-2013, 07:14 PM   #2
DIY staff
Rewards Points: 7,174
Depends on the layout----if the tile pattern matches the wall--then I might tile near it --then tile the niche--then finish the wall----if the tile is diagonal in the niche and straight on the wall---then niche first.
Also---will the niche opening be picture framed with bull nose?
A lot depends on that treatment---
Trucon01 (05-15-2013)
Old 05-15-2013, 07:42 PM   #3
Trucon01's Avatar
Rewards Points: 510
Yes, I did plan on picture framing around the niche. Tile will be square on the wall, not diamond.
Let me know if you need to know anything else!!
Thanks for responding.
Old 05-17-2013, 07:02 AM   #4
DIY staff
Waterproof that opening very well----Paint on some Hydroban or redguard---
Pitch the bottom so it drains---
Old 05-17-2013, 08:32 AM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Water proof everything before tile. Don't use the liquid if there is vapor barrier on the studs behind your shower walls.
JetSwet is offline   Reply With Quote
Old 05-17-2013, 04:16 PM   #6
Trucon01's Avatar
Rewards Points: 510
Thanks. Yeah, thats already all done. I have a RediTile insert screwed to the studs, silicone around the edges and then 4 coats of Redgard on all walls.
Am I to assume I tile the back of the niche first, then the 4 sides, they the picture frame effect, then the rest of the back wall?
Old 05-17-2013, 04:19 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
What's on your studs? I hope not a moisture barrier?
Old 05-17-2013, 04:25 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
That is going to be one tasty sandwich!.....eek!
Old 05-17-2013, 05:25 PM   #9
Trucon01's Avatar
Rewards Points: 510
Roxul between studs, 1/2 durock, then redgard. No plastic vapor barrier.
Old 05-17-2013, 05:27 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
Ok good got fighted for a sec
Old 05-18-2013, 07:02 AM   #11
DIY staff
Back wall first--then the sides---
Old 05-25-2013, 09:42 PM   #12
Rewards Points: 4,792
It will probably look better if you tile the back of the niche first. This is because of the angle from which the bather will be looking. Google coping trim to get an idea of the basic concept. When you cope, you have to decide which angle people will most likely be looking from to decide which end to cope.
jeffnc is offline   Reply With Quote
Shower Niche help... fatboy1729 Tiling, ceramics, marble 4 03-12-2013 08:14 AM
tiling a built-in shower seat diy'er on LI Tiling, ceramics, marble 14 02-25-2012 09:14 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 08:40 PM
Tiling Around A Shower Pan GLASSMAN1 Remodeling 3 02-03-2008 09:23 PM
