-   Tiling, ceramics, marble (http://www.diychatroom.com/f84/)
-   -   Shower Niche Tiling (http://www.diychatroom.com/f84/shower-niche-tiling-179657/)
Trucon01 05-15-2013 06:09 PM
Shower Niche Tiling
Hi All,
I have a two-fold question.
1.
When tiling a shower, should you tile the shower niche / insert first or last?
2.
Whenever you do tile the niche, should you tile the back first and then all 4 sides, or tile the back last?
The niche will have horizontal glass tile while the sides will have regular tile.
Thanks.
oh'mike 05-15-2013 06:14 PM
Depends on the layout----if the tile pattern matches the wall--then I might tile near it --then tile the niche--then finish the wall----if the tile is diagonal in the niche and straight on the wall---then niche first.
Also---will the niche opening be picture framed with bull nose?
A lot depends on that treatment---
Trucon01 05-15-2013 06:42 PM
Yes, I did plan on picture framing around the niche. Tile will be square on the wall, not diamond.
Let me know if you need to know anything else!!
Thanks for responding.
oh'mike 05-17-2013 06:02 AM
Waterproof that opening very well----Paint on some Hydroban or redguard---
Pitch the bottom so it drains---
JetSwet 05-17-2013 07:32 AM
Water proof everything before tile. Don't use the liquid if there is vapor barrier on the studs behind your shower walls.
Trucon01 05-17-2013 03:16 PM
Thanks. Yeah, thats already all done. I have a RediTile insert screwed to the studs, silicone around the edges and then 4 coats of Redgard on all walls.
Am I to assume I tile the back of the niche first, then the 4 sides, they the picture frame effect, then the rest of the back wall?
JetSwet 05-17-2013 03:19 PM
What's on your studs? I hope not a moisture barrier?
JetSwet 05-17-2013 03:25 PM
That is going to be one tasty sandwich!.....eek!
Trucon01 05-17-2013 04:25 PM
Roxul between studs, 1/2 durock, then redgard. No plastic vapor barrier.
JetSwet 05-17-2013 04:27 PM
Ok good got fighted for a sec
oh'mike 05-18-2013 06:02 AM
Back wall first--then the sides---
jeffnc 05-25-2013 08:42 PM
It will probably look better if you tile the back of the niche first. This is because of the angle from which the bather will be looking. Google coping trim to get an idea of the basic concept. When you cope, you have to decide which angle people will most likely be looking from to decide which end to cope.
