Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 12-06-2012, 01:59 AM   #1
Shower liner question
Hi to all, when building a custom shower base after building the preslope bed and laying in a plastic liner of 15 mil poly, what bonds the tile thinset to the plastic liner or is it sort of floating ? Thanks to all who reply.
Sammy 2 is offline   Reply With Quote
Old 12-06-2012, 03:37 AM   #2
Super Moderator
How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
I've only use a PVC or rubber liner----
Read the link above---and then come back and ask questions---Mike--
Sammy 2 (12-06-2012)
Old 12-06-2012, 09:07 AM   #3
Thanks, I am following that link and methods used. So we are saying the liner should be rubber, thick poly won't work ? Does thinset stick to rubber ? vs the plastic makeup of Poly ? Or is it just floating on top. I live in small town BC Canada and don't have easy access to materials needed. I do have access to 15 mil poly that is designed for under concrete slab water barrier use. That was my reason for wanting to use it instead of Kerdi or other liners. I see the writer says that the thinset should be better than an inch thick at the drain. Thanks again.
Old 12-06-2012, 09:59 PM   #4
Tileguy
JazMan's Avatar
Sammy,
I know you said you're following that link and method, but we know you're not doing that yet.
The shower membrane used in a traditional method is 40 mils, not 15mil poly and is sitting on a pre-slope, with another 1 1/2" or thicker deck mud over it which will be the base for the tiles. Or you could go with surface membrane like Kerdi. The way you described your intentions it seems you'd like to do a method similar to the Kerdi, but you have the wrong products.
Go back and study, then come back. For what it's worth I recommend doing a Kerdi shower with Kerdi drain etc.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
Basement Tiled shower pan drain question heinlein0311 Plumbing 3 10-26-2012 10:35 AM
New Shower (Plumbing valve question) REDRUM Plumbing 9 10-16-2012 12:54 PM
Quick question: shower drain gaskets MANGINA Plumbing 8 09-08-2012 08:32 PM
Multiple Shower Head/Water Pressure Question MikeDobbs Plumbing 13 02-28-2012 12:40 AM
New shower venting question jwbr Plumbing 0 11-28-2010 03:05 PM
