Shower Floor Pre Pitch - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-05-2014, 09:13 AM   #1
Rewards Points: 14
Shower floor pre pitch
I'm remodeling a bathroom and wondering if a "pre pitch" is absolutely necessary. Here are the details. Bathroom is in ground level (no basement). Concrete subfloor. I've framed the new shower and also used self leveling concrete to level the room. Now, I'm wondering if it's necessary to do a pre pitch, then place the shower liner and do another pitch. Can't I just put the liner down and do one pitch to the drain? Thanks in advance.
ofcjosh is offline   Reply With Quote
Old 11-05-2014, 10:10 AM   #2
Rewards Points: 62
A pre-pitch allows water that seeps past the tile and final slope to be directed into the weeping holes of the drain. So yes, it's necessary to do two pitches if you want the job done right. Make sure you add some gravel around the weeping holes to prevent the mortar from clogging them.
Zorfox is offline   Reply With Quote
Old 11-05-2014, 04:35 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes it is necessary.
XXX
Old 11-05-2014, 09:34 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 678
ofcjosh-- Please only start one thread of the same topic/question.
I moved your original question to the tile board- but listen to Bud- he'll do you right...
Old 11-05-2014, 11:05 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Assuming you are using the correct "clamping drain" you wouldn't want to overlook the pre-slope. It is most important as explained in Post #2 above.
Your tile shower floor will not and will never be waterproof as far as the tile and concrete is concerned. It is the vinyl pan that makes the system waterproof. Sloping the pan keeps water from accumulating on top of the pan and becoming stagnate and stinky in a short time. Using the proper "clamping-flange shower floor drain" is a must. When installed properly this style drain uses integral weep channels to take water that gets through the floor straight to the drain via the sloping vinyl pan.
XXX
Old 11-06-2014, 02:38 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 388
As already stated, you should do two slopes when building a shower using the old traditional method. However you can use the Kerdi method which requires only a single slope.
It's a system using the Kerdi fabric or tray and the Kerdi Drain. I think it's superior to the old method.
Jaz
Shower floor pre pitch-img_7834.jpg   Shower floor pre pitch-img_7835.jpg   Shower floor pre pitch-img_7836.jpg   Shower floor pre pitch-img_7838.jpg   Shower floor pre pitch-img_7837.jpg
Old 11-06-2014, 04:32 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I too would recommend using the Schluter Systems Shower Kit and save a bunch of time and hard work over doing it the old fashion way.
XXX
Old 11-07-2014, 12:03 PM   #8
Rewards Points: 2,600
i would have chosen a linear drain, but that aside, i dont have any specific answer.
concrete_joe is offline   Reply With Quote
Old 11-09-2014, 08:34 AM   #9
Rewards Points: 4,796
JazMan showed the single pitch, but it gets even better with Kerdi. You don't have to do any of that work at all if you use Kerdi's premade (presloped obviously) pan. It comes with their shower kit. Then you don't have to make any slopes at all.
You get rid of the second slope because you tile directly to Kerdi - you can't tile to a regular shower liner and that's the only reason you need that second layer of mortar. You get rid of the first slope because the Kerdi pan is premade.
So just out of curiosity, why did you build that one yourself JazMan?
jeffnc is offline   Reply With Quote
Old 11-09-2014, 11:37 AM   #10
Rewards Points: 62
I've never used the Kerdi system because of the cost. I didn't realize you could buy the materials separately until I saw Jaz's post. The cost of the Styrofoam parts are ridiculous so I see why you made your own.
This seems like the perfect solution to repair a leaking existing pan. Is there any reason you couldn't knock the old tile out keeping the slope and old liner. Then install the Kerdi drain and fabric over that? It seems a heck of a lot easier than replacing it the traditional way.
Old 11-09-2014, 04:46 PM   #11
That might work, but getting the old drain out and the new one to fit might be an issue. Schluter makes some kind of conversion drain, I've seen, but haven't used it.
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
No pressure in my shower loki993 Plumbing 6 08-08-2012 03:09 PM
How to pitch L-shaped half-wall for shower? Andy S. Kitchen & Bath Remodeling 8 03-31-2011 11:37 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 01:02 PM
