Shower Floor Grout Prob. - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 05:36 PM   #1
MEH
I read a ton of posts but just need some clarification.
Our shower is just over a year old, we have some small chunks of Grout coming up from the floor. The tile is slate, and the grout used was sanded, dry mix. (not the pre-mixed stuff). Grout level 3.
There was also a sealant (3 coats put on top of the floor).
I understand from other post, if grout is cracking it is due to movement, and what is behind. The construction of the floor was a pan, concrete, thin set, and the tiles. 1/8" grout.
We have multiple shower heads/body sprays installed. However, the grout issue appears to only be where one of the main shower head sprays on the floor.
I will say, we paid a fortune for this shower, and had a 'professional' install it....I read in some post, you get bad work, because the owner is cheap, or tries to do thing that are not in code, etc. Not the case here. We paid for it to be done right, no doubt.
Is the issue that Sanded grout was used instead of Unsanded (read that in a post)????
It's a small problem right now, but I don't want it to be a huge one. Any thought or ideas would be incredible!
MEH is offline   Reply With Quote
Old 11-05-2010, 07:55 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The sanded grout is not the issue. What you are experiencing is very likely "grout erosion" from the spray and body-drips I think. Seen it many many times. Typically it is caused because the grout is a little weak. This is usually caused by over-watering the grout when mixing it at the time of installation.
Call the installer and see if he is willing to redo the floor grout.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
MEH (11-06-2010)
Tags
floor , grout , shower , slate , tile
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
