Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Flooring > Tiling, ceramics, marble
Old 05-30-2012, 12:19 AM   #1
Shower floor
How would I fix my shower floor. It is uneven .
It is 3'4"x4'7"
Gardec is offline   Reply With Quote
Old 05-30-2012, 06:05 AM   #2
Super Moderator
Shower floor
Do you know how it was built?
If it's a mud pan with a liner under the bottom--you could remove the tiles--even up the surface with Feather finish and install new.
If the pan is waterproofed with a surface membrane like Hydroban or Kerdi---you will damage the membrane--so leave it alone---
Old 05-30-2012, 12:45 PM   #3
Stuck in the 70's
Blondesense's Avatar
Shower floor
Don't see any obvious problems.
Does it slope correctly?
What exactly is uneven?
You could cause serious issues trying to correct something that is just cosmetic.
Old 05-30-2012, 12:47 PM   #4
Shower floor
The water sets to right of drain, to left is fine
Old 05-30-2012, 03:12 PM   #5
Newbie Bill
Shower floor
Squeegie?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-31-2012, 01:27 PM   #6
Stuck in the 70's
Shower floor
I'm no expert, but I think I would get a squeegee and live with it. At least for awhile.
Like Mike said, not knowing how the pan was built is the kicker. I would be afraid of making an annoying little situation a heck of a lot worse.
Maybe Jaz will come by and offer some other suggestion, but in the meantime keep a close eye out for any other water or moisture where it doesn't belong. Especially anywhere around or under that bench.
Old 06-09-2012, 10:41 PM   #7
Shower floor
I would live with it if its not leaking any where. However if you cant live with it, you might be able to raise the drain and install new tile over the top of the old. There is a special thin set to do this. You would have to be pretty good with the trowel to get it to slope better though. I havent done this personaly, but its prob the only "easy" option.
darobi2459 is offline   Reply With Quote
Old 06-12-2012, 08:57 PM   #8
Shower floor
get a drain extension and tile over it
jrenfro27 is offline   Reply With Quote
Old 06-12-2012, 09:54 PM   #9
JetSwet's Avatar
Shower floor
This sounds like the easiest way to fix it, although I don't trust the type thinset that can be used for tile on tile at least deglaze the existing tile.
JetSwet is offline   Reply With Quote
Old 06-16-2012, 10:42 PM   #10
Shower floor
Im with you jetswet, it is a hydroment product i believe. I have used it twice and no prob, but i still wouldn trust it
why fix if it aint broke?
The Following User Says Thank You to darobi2459 For This Useful Post:
JetSwet (06-17-2012)
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 10:03 PM
Travertine Shower Floor smstone Flooring 2 06-21-2011 07:25 PM
Shower Floor Bobo Jenkins Flooring 0 05-24-2011 09:10 PM
Lowering Shower floor Steve Burke Kitchen & Bath Remodeling 3 02-16-2010 12:21 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
