Shower Floor - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 03:54 AM   #1
Shower Floor
Hello,
I'm about to set tile in a new shower. What is the best adhesive for laying ceramic tile over durock board? And, also for the floor, what is used to set the 2x2 tiles for the floor?
albany is offline   Reply With Quote
Old 04-17-2012, 05:11 AM   #2
DIY staff
Rewards Points: 7,174
I'm a little worried about your shower-- Shower pans need to be waterproof--
Powdered modified thinset is the best--stay away from premixed adhesives--they are water soluable and must not be used in a wet area
Typically a PVC membrane or rubber is installed over a pre sloped sufloor--then the membrane--then a layer of deck mud--then tiles are set into a modified thinset---
What exactly are you doing?
Water will seep through tile and grout --they are not waterproof---concrete is not waterproof,Either--water will saturate that and eventually reach the wood below---Mike--
Old 04-17-2012, 05:29 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
What Gary said = Do you have a membane installed?
Do you have the floor sloped towards the drain?
More information here: http://www.ontariotile.com/preslope.html
- Build Well -
Travertine Shower Floor smstone Flooring 2 06-21-2011 06:25 PM
Shower Floor Bobo Jenkins Flooring 0 05-24-2011 08:10 PM
Lowering Shower floor Steve Burke Kitchen & Bath Remodeling 3 02-15-2010 11:21 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Shower floor grout cracking radnrs Flooring 11 09-14-2008 08:49 PM
