Shower Faucet Hole - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 03:41 PM   #1
Shower faucet hole
How big should the hole be in my tile for my shower faucet? I may have not left myself enough room. DO you guys think I could cut it out bigger with a grinder/diamond blade?
RegLearning is offline   Reply With Quote
Old 03-03-2012, 03:46 PM   #2
DIY staff
Rewards Points: 7,174
What brand ?
Moen is very forgiving --Delta,no so much---
Try the trims --do they fit?
Old 03-03-2012, 04:06 PM   #3
Rewards Points: 12,858
No Picture, no brand name, what does the instrutions say?
Old 03-03-2012, 04:40 PM   #4
Sorry guys.
It's a moen positemp. I figured as long as the screws would go into the valve that would be big enough of a hole. Is that to small? Here's a pic of the valve and the showerhead spout. Excuse the crooked glass tiles, it was my first time..lol
Old 03-03-2012, 05:24 PM   #5
DIY staff
It should have been 5 1/2" across---why didn't you leave in the plastic trim ring and cut around that?
Shame on you.
All right---I said what you expected me to say---Now ,go ahead and install your trims--I believe you will be successful--slip them on and let us know.--Mike---
If that doesn't work--let us know.
Old 03-03-2012, 06:01 PM   #6
This is my old valve so that's the way the builder put it in.
Old 03-03-2012, 06:45 PM   #7
DIY staff
Got you---first time tiling,so you didn't have anything to compare it to---Moen plates are quite flat,so I think that you are going to be O.K.--do you have a cover to try?
Another thing to know---if the stem is in the wall to far--there is an extension stem available from Moen or a local plumbing supply house.
touchy shower faucet crosssums Plumbing 1 02-08-2012 05:08 PM
old two handled shower broken. Mary Thorman Plumbing 0 10-05-2011 08:05 PM
Bath faucet pop-up drain rod won't fit sink hole location seavlad Plumbing 7 02-03-2011 07:23 PM
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 11:58 PM
Does not fully go from faucet to shower desimonkey Plumbing 1 04-21-2009 03:59 PM
