Shower - DensShield - Propr Construction - Tiling, ceramics, marble - DIY Chatroom Home Improvement Forum
Old 04-07-2015, 06:52 AM   #1
Rewards Points: 14
Shower - DensShield - Propr construction
Hi,
I'm building a barrier-free shower in my basement.
The floor is concrete (poured 6 months ago)
The frame is 20ga equivalent steel.
I got 5/8in DensShield for the walls and ceiling.
I like the Fiandra Beige 12 in. x 24 in. Glazed Porcelain Floor and Wall Tile for the walls, but did not buy them yet. Not sure if they would be good for the ceiling. Also need some matching mosaic for the floor.
After reading the manufacturer's documentation and lots of conflicting info on the web I need to come up with a shopping list and an action plan.
GKL7 is offline   Reply With Quote
Old 04-07-2015, 06:56 AM   #2
Rewards Points: 14
First things first, GP recommends "Buglehead, rust thread, sharp point rust resistant drywall screws" installed every 6" along framing.
Does it translate to just any 1.25" black drywall screw or there is something better?
The Following User Says Thank You to GKL7 For This Useful Post:
gregzoll (04-08-2015)
Old 04-07-2015, 07:52 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 3,060
No, those cheapo drywall screws is not what they're describing.
What is going on the floor of this shower? If it's tiles, you'll want to study the diagram located in their data sheet and online.
Jaz
Tile 4 You LLC Troy, MI - Consulting by phone/internet -PAYPAL
DITRA Installs - KERDI Watertight-Mold-Free Showers. I have NEVER made a mistake, I thought I did ONCE, but, I was WRONG! A+ BBB rating - est. 1987 - over 50 yrs. exp.
JazMan is online now   Reply With Quote
Old 04-07-2015, 09:49 PM   #4
Dark Knight
Streeter1981's Avatar
Rewards Points: 18
Send a message via AIM to Streeter1981
No do not use regular drywall screws, definitely use what the mfr. recommends. Especially somewhere wet, you want to go with what will last.
Streeter1981 is offline   Reply With Quote
Old 04-08-2015, 05:58 AM   #5
Rewards Points: 14
I have hard time finding better screws...
Could you post some HD, Lowes, Amzon etc. examples?
(I'll move on to the floor and other items one I have my screws figured out)
Old 04-08-2015, 08:51 AM   #6
Rewards Points: 320
Have you checked out the product information sheets on what to use for attaching the board? That should give you type, diameter and length for various materials you're screwing to. You'll probably need self drilling screws since you're using 20 gauge metal, unless you want to drill pilot holes. They will need to be zinc plated. I would try Fastenal or an online source, even ebay, because I don't think the big box stores will carry them.
rustyjames is offline   Reply With Quote
Old 04-08-2015, 10:33 AM   #7
Tileguy
JazMan's Avatar
Make sure you know what step #2 will be before you start #1. It's all kinda connected. I'm saying this cuz after studying how the Dens gets installed at the bottom of showers, you might wanna use something else. Go look at DS002.
Jaz
Old 04-08-2015, 01:55 PM   #8
Rewards Points: 14
JazzMan, I'm using One Coat Float, DS007.
RustyJames, I quoted the product sheet in my first post regarding the screws. Using your zinc plated idea I found this locally available:
Grabber 1-lb #6 x 1.25-in Bugle-Head Zinc-Plated Drywall Screw
Old 04-08-2015, 02:29 PM   #9
Rewards Points: 14
On to step two.
Mortar bed or custom made tile basin (3-pound high density EPS foam)?
Laying a large mortar bed (53"x75") does not sound like a DIY task. I can hire a pro to do it, but I think even he would have hard time making it a perfect shape at that size.
See DS007 for reference:
Old 04-08-2015, 03:37 PM   #10
Tileguy
JazMan's Avatar
So you're doing a mud job then. They tell you to install the mud per TCNA method W231. Are you familiar with W231? I don't understand why you'd wanna build a shower wall that way even if you were a seasoned mud guy. I don't see the point of Dens with lath and then " of mud over it if you're a DIY'er. Both sketches are very deceiving as the thicknesses are not true.
I'm thinking you're not gonna follow the GP data, but hybrid with the Merkrete system so it's not gonna be like DS007.
Jaz
Old 04-08-2015, 05:40 PM   #11
Rewards Points: 320
If that's the recommeded size/length than those will be fine.
Old 04-08-2015, 07:24 PM   #12
Rewards Points: 14
Wasn't familiar with W231 but I can Google.
W231 is for "WALLS, INTERIOR Wood Studs or Furring, Cement Mortar"
My case would be W242 "WALLS, INTERIOR, Metal Studs Gypsum Board, Organic Adhesive".
But they both for walls.
My question is about the floor. Which one of the following is better / easier?
A sloped mortar bed coated with a layer of Hydroguard + fabric (so water never gets to the wallboard's bottom edge )
- or -
A custom made foam shower slope, like KBRS or similar also coated with a waterproofing layer.
Old 04-08-2015, 07:47 PM   #13
Tileguy
JazMan's Avatar
First of all I hope you do NOT use organic adhesive for a shower.
As for W231 I'm just quoting the directions GP wants you to follow. Personally I think their directions are convoluted to the max. Those diagrams are ridiculous and they also mention the option of using organic adhesive aka mastic. That tells me they don't care how long your shower will last, definitely not 'best practice'.
What is the point of using One Coat Float system?
According to the TCNA Handbook, W231/W241 is for both wood or metal studs, but the thickness of the wall mud is min. " to 1 ". I think GP is quoting the wrong method.
You don't wanna do W242 for a shower! Where did you get that idea?
I like the Kerdi Drain/Membrane method the best.
Jaz
Old 04-09-2015, 08:53 AM   #14
Rewards Points: 14
I just pulled W242 of Google to have a response to your W231
Once I decided on how to create the sloped floor I'm planning to use a waterproof membrane on it (Kerdi or similar) and a couple of of inches up the wall.
If I decide to create a mortar slope floor (for the whole bathroom, as it is barrier-less), what kind of mortar would I use? (Considering that it'll be waterproofed from the top, if that matters)
Old 04-09-2015, 11:40 AM   #15
Tileguy
JazMan's Avatar
Being on a slab, the easiest way is to make a small speed-bump where the curb would normally be. Install mosaics in a strip several inches wide to accent the hump. This way you keep the floor of the bathroom as is. You'll have to raise the shower floor though to slope it.
Otherwise you mud the entire room, but that means the entire room will be a couple inches higher than it is now.
Ideally curbless shower bathrooms woulda been planned ahead of time and the whole room would be 2-3 inches lower to start.
Jaz
Tags
densshield , shower
Shower install on outside double wall construction boerssd Plumbing 0 01-16-2012 01:02 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
